PowerA Spectra Infinity Enhanced Vibration Motors Replacement
  1. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: step 1, image 1 of 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: step 1, image 2 of 2
    • Flip the controller so the back is facing up.
  2. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 2, image 1 of 1
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
  3. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 3, image 1 of 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 3, image 2 of 2
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
  4. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 4, image 1 of 1
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
  5. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 5, image 1 of 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 5, image 2 of 2
    • Use your hand to separate the motherboard from the face plate.
  6. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: step 6, image 1 of 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: step 6, image 2 of 2
    • Remove the four 7.9 mm screws using a Phillips #0 screwdriver.
  7. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 7, image 1 of 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 7, image 2 of 2
    • Use tweezers to unplug the small plug connecting the motors to the motherboard.
    • A firm grip may be necessary for this step.
  8. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 8, image 1 of 3 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 8, image 2 of 3 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: step 8, image 3 of 3
    • Remove the completely freed vibration motor from the motherboard.
2 other people completed this guide.
Kevyn Jorge
1,012 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 24
All Time: 344
