PowerA Spectra Infinity Enhanced Faceplate Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
67
All Time:
860
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace/remove the faceplate of a Power A Spectra Infinity Enhanced Xbox controller.
The faceplate may need to be replaced if it is chipped, cracked, or scratched. Please ensure that the controller is not plugged in before taking it apart.
Tools
    1. PowerA Spectra Infinity Enhanced Faceplate Replacement, Motherboard: step 1, image 1 of 2 PowerA Spectra Infinity Enhanced Faceplate Replacement, Motherboard: step 1, image 2 of 2
      • Flip the controller so the back is facing up.
      Ask FixBot
    2. PowerA Spectra Infinity Enhanced Faceplate Replacement: step 2, image 1 of 1
      • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
      Ask FixBot
    3. PowerA Spectra Infinity Enhanced Faceplate Replacement: step 3, image 1 of 2 PowerA Spectra Infinity Enhanced Faceplate Replacement: step 3, image 2 of 2
      • Unlock the trigger locks before removing the backplate.
      • This will make taking the plate off easier.
      • Use your fingers and carefully remove the backplate.
      Ask FixBot
    4. PowerA Spectra Infinity Enhanced Faceplate Replacement: step 4, image 1 of 1
      • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
      Ask FixBot
    5. PowerA Spectra Infinity Enhanced Faceplate Replacement: step 5, image 1 of 2 PowerA Spectra Infinity Enhanced Faceplate Replacement: step 5, image 2 of 2
      • Use your hand to separate the motherboard from the face plate.
      Ask FixBot
    1. PowerA Spectra Infinity Enhanced Faceplate Replacement, Faceplate: step 6, image 1 of 1
      • Remove the buttons from the face plate (d-pad, action buttons, start/select, etc).
      Ask FixBot
    2. PowerA Spectra Infinity Enhanced Faceplate Replacement: step 7, image 1 of 1
      • Remove two 10 mm screws holding the bumper to the faceplate using a Phillips #0 screwdriver.
      Ask FixBot
    3. PowerA Spectra Infinity Enhanced Faceplate Replacement: step 8, image 1 of 2 PowerA Spectra Infinity Enhanced Faceplate Replacement: step 8, image 2 of 2
      • Remove the single 7.9 mm screw holding the bumpers to the faceplate using a Phillips #0 screwdriver.
      Ask FixBot
    4. PowerA Spectra Infinity Enhanced Faceplate Replacement: step 9, image 1 of 1
      • Use your hand to separate the faceplate from the bumpers.
      Ask FixBot
Kevyn Jorge
1,020 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 67
All Time: 860
