Introduction
Replace your power steering rack &pinion
From inside the vehicle on drivers side use a 11mm socket to remove the three nuts that secure the boot to the firewall
Using a 10mm sockstRemove the two pinch bolts form the shaft and remove shaft & boot
remove the two Nuts and Bolts that secured flex pipe to the y pipe
From inside the engine compartment remove the three nuts that secure the strut to the strut Tower on both sides
place a floor jack with a short piece of 2 by 6 under the transmission pan
Raise Jack until it just starts to lift the transmission
loosen the two front bolts of the subframe but do not remove
remove the two Bolts from the rear of the subframe
Slowly lower jack in till you have about 4 inches of clearance
Remove the two nuts that secure the steering rack to the subframe
Lift the steering rack up until the bolts clear rotate rack to gain access to the hose fittings and remove
Slide rack to the left and remove thru drivers side wheel well
2 other people completed this guide.
