Power Tools Internal battery Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
12
Past 7 Days:
114
Past 30 Days:
432
All Time:
1,783
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The battery that I am using is a DeWalt 20V Max Lithium Ion DCB 207. Most power tool batteries use internal 18650 batteries. I will be replacing the internal 18650 batteries.
Parts
Tools
    1. Power Tools Internal battery Replacement, Removing Screws: step 1, image 1 of 1
      • Start by removing the 4 screws using the TR10H
      • Set the screws aside
      Ask FixBot
    2. Power Tools Internal battery Replacement, Separating Battery Case: step 2, image 1 of 2 Power Tools Internal battery Replacement, Separating Battery Case: step 2, image 2 of 2
      • Pry the two shells apart. It may be difficult to open, and it may require that you use a flat-head screwdriver to help pry it open.
      • There is a spring inside that is used for the locking mechanism, which is not secured and will fall out when the device is opened. Marked in orange
      Ask FixBot
    3. Power Tools Internal battery Replacement, Removing Battery Pack: step 3, image 1 of 2 Power Tools Internal battery Replacement, Removing Battery Pack: step 3, image 2 of 2
      • Remove the battery from the bottom shell. There may be glue, or it may be difficult to remove; use the pliers to help remove the battery pack. Areas that pliers can safely hold onto the pack are marked in green.
      • USE caution not to puncture the batteries, as they can release toxic fumes or may start a fire
      Ask FixBot
    4. Power Tools Internal battery Replacement, Battery Cell Mesurment: step 4, image 1 of 1
      • Use a multimeter to determine if any battery cells can be reused. But since the terminals read zero, which means that my cells no longer have voltage.
      • If your cells have voltage, the safe operating range of 18650 batteries is 2.9V and 3.8V
      Ask FixBot
    5. Power Tools Internal battery Replacement, Desoldering: step 5, image 1 of 2 Power Tools Internal battery Replacement, Desoldering: step 5, image 2 of 2
      • Use caution when desoldering. Excessive heat to the batteries, even at zero voltage, can still release toxic fumes and cause a fire.
      • Use proper ventilation and a work station. A recommendation is to use a chisel tip for the soldering iron to heat the solder. And use a copper wick to remove the solder.
      Ask FixBot
    6. Power Tools Internal battery Replacement, Removing the Main Power Leads: step 6, image 1 of 3 Power Tools Internal battery Replacement, Removing the Main Power Leads: step 6, image 2 of 3 Power Tools Internal battery Replacement, Removing the Main Power Leads: step 6, image 3 of 3
      • The main power lead (Red and Black wire) solder joint may use a solder that requires greater heat than the solder iron can provide. Use pliers to remove the nickel strip from the battery
      • Since the Main leads are not in a desirable condition, I will cut and add a new nickel strip to the main power leads
      Ask FixBot
    7. Power Tools Internal battery Replacement, Removing the Battery's: step 7, image 1 of 3 Power Tools Internal battery Replacement, Removing the Battery's: step 7, image 2 of 3 Power Tools Internal battery Replacement, Removing the Battery's: step 7, image 3 of 3
      • Start by noting the polarity of the batteries and how they are connected
      • Then, by carefully removing the nickel strip from the batteries using pliers
      • Dispose of the batteries following your area's battery disposal procedures.
      Ask FixBot
    8. Power Tools Internal battery Replacement: step 8, image 1 of 1
      • Add the new batteries in the polarity that you noted
      Ask FixBot
    9. Power Tools Internal battery Replacement, Spot Weld New Batterys: step 9, image 1 of 3 Power Tools Internal battery Replacement, Spot Weld New Batterys: step 9, image 2 of 3 Power Tools Internal battery Replacement, Spot Weld New Batterys: step 9, image 3 of 3
      • Use safety glass when spot welding, as sparks may fly
      • Set your spot welder to the appropriate settings when welding the batteries, as the heat can puncture them
      • Since the batteries that I'm using have a separate cable, you may have to cut a smaller nickel strip to reconnect the cable marked in red
      • To reconnect the main power leads, add a new nickel strip by spot welding the strip to the power lead. Shown in orange
      Ask FixBot
    10. Power Tools Internal battery Replacement, Re-solder the cables: step 10, image 1 of 1
      • Re-solder the cables removed in step 5
      Ask FixBot
    11. Power Tools Internal battery Replacement, Re-assemble: step 11, image 1 of 2 Power Tools Internal battery Replacement, Re-assemble: step 11, image 2 of 2
      • Place the battery pack into the case, the 4 screws, and the spring
      • And test to see if it charges ( My battery shows blinking, so I know it is charging)
      Ask FixBot
Thank you for following along, and I hope that this guide helps you fix your battery.
3 other people completed this guide.
Eli Pedroza
253 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 114
Past 30 Days: 432
All Time: 1,783
