Power Macintosh G3 Minitower Processor Module Wire Screw Replacement
      • Press the green release button on top of the side access panel.
      • Pull off the side access panel to get inside the computer.
      • When putting the side access panel back on, make sure that the bottom of the panel lines up with the rail on the bottom, and that the chassis is locked with the green latches.
      Ask FixBot
      • Lay the computer on its side, ensuring that where the side access panel was is facing up.
      Ask FixBot
      • Unlock the top chassis by moving the two green locking latches upward and outward.
      • Using the handle, gently swing the top chassis up and out until it rests firmly on the work surface.
      Ask FixBot
      • Using a Phillips screwdriver, unscrew the screw on the logic board holding the processor module wire in place.
      • When screwing down the wire, be careful not to damage the capacitor next to the screw hole.
      Ask FixBot
LeoI07
1,600 Reputation
17 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 33
All Time: 256
