Fix Your Stuff
Right to Repair
Store
Archived
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Archived
Introduction
This is meant to be a private prereq guide.
Parts
No parts specified.
  1. The hard drive is located in the back right corner of the case.
    • The hard drive is located in the back right corner of the case.
  2. Remove the flat ribbon cable by pulling with substantial force.
    • Remove the flat ribbon cable by pulling with substantial force.
  3. Remove the screw holding the hard drive to the computer.
    • Remove the screw holding the hard drive to the computer.
  4. Pull the drive up and out of the computer.
    • Pull the drive up and out of the computer.
  5. Remove the multicolored cable by grasping the plastic connector on either side and pulling with substantial force.
    • Remove the multicolored cable by grasping the plastic connector on either side and pulling with substantial force.
10 other people completed this guide.
Ryan Bylard
1,280 Reputation
5 Guides authored
Cal Poly, Team 14-41, Regan Winter 2010 Member of Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
4 Members
17 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 7,291
