Repairing PowerMac G4 M5183 Processor
  1. Repairing PowerMac G4 M5183 Processor, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Repairing PowerMac G4 M5183 Processor, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Repairing PowerMac G4 M5183 Processor, Heat Sink: step 2, image 1 of 2 Repairing PowerMac G4 M5183 Processor, Heat Sink: step 2, image 2 of 2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Repairing PowerMac G4 M5183 Processor: step 3, image 1 of 1
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Repairing PowerMac G4 M5183 Processor, Processor: step 4, image 1 of 2 Repairing PowerMac G4 M5183 Processor, Processor: step 4, image 2 of 2
    • Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
    • Remove processor by pulling vertically upwards.
Justin Petrilli
3,114 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
25 Guides authored
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 39
All Time: 12,084
