Installing Power Mac G4 M5183 Power Supply
  1. Installing Power Mac G4 M5183 Power Supply, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Installing Power Mac G4 M5183 Power Supply, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Installing Power Mac G4 M5183 Power Supply, Main Fan: step 2, image 1 of 2 Installing Power Mac G4 M5183 Power Supply, Main Fan: step 2, image 2 of 2
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Installing Power Mac G4 M5183 Power Supply: step 3, image 1 of 1
    • Remove the power cable from the fan and detach bracing.
  4. Installing Power Mac G4 M5183 Power Supply, DVD-ROM Drive: step 4, image 1 of 2 Installing Power Mac G4 M5183 Power Supply, DVD-ROM Drive: step 4, image 2 of 2
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  5. Installing Power Mac G4 M5183 Power Supply: step 5, image 1 of 1
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  6. Installing Power Mac G4 M5183 Power Supply: step 6, image 1 of 3 Installing Power Mac G4 M5183 Power Supply: step 6, image 2 of 3 Installing Power Mac G4 M5183 Power Supply: step 6, image 3 of 3
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
  7. Installing Power Mac G4 M5183 Power Supply, Power Supply: step 7, image 1 of 2 Installing Power Mac G4 M5183 Power Supply, Power Supply: step 7, image 2 of 2
    • Remove the 3 hex screws on the back of the case.
    • Remove the single screw on the side of the power supply casing with the Phillips #1 screwdriver.
  8. Installing Power Mac G4 M5183 Power Supply: step 8, image 1 of 2 Installing Power Mac G4 M5183 Power Supply: step 8, image 2 of 2
    • Remove power cable from the logic board.
    • Remove power cable from hard drive.
    • Pull the power supply out and towards yourself.
Justin Petrilli
3,114 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
25 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 61
All Time: 23,612
