Introduction
This guide will show you how to remove the PowerMac logic board.
Pull on outer latch.
Lower door until it is level with your work surface.
Use the spudger to pry the clips horizontally off of the heat sink.
Fully remove the clips by lifting upwards.
Remove the single screw with the Phillips #1 screwdriver.
Pull the graphics card up and out.
Remove the six indicated cables attached to the logic board.
Use the spudger to remove the modem cable as indicated.
Unfasten 3 Phillips #1 screws on Mother Board as well as the 3 screws revealed beneath the heat Sink on the CPU board.
Slide the logic board about a quarter of an inch to free it from the three retaining pins.
Pull upwards and outwards to fully remove the logic board.
After removing the (3) #2 philips screws, remove the (4) 1/4" hex nuts, then slide as directed and remove board.
