Installing PowerMac G4 M5183 Internal Battery
  1. Installing PowerMac G4 M5183 Internal Battery, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Installing PowerMac G4 M5183 Internal Battery, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Installing PowerMac G4 M5183 Internal Battery, Internal Battery: step 2, image 1 of 2 Installing PowerMac G4 M5183 Internal Battery, Internal Battery: step 2, image 2 of 2
    • Locate the battery.
    • Remove and replace battery.
    • Push the PMU button once, and only once, to reset the power supply.
Justin Petrilli
3,114 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
25 Guides authored
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 110
All Time: 25,376
