Installing Apple PowerMac G4 Cube Modem
  1. Installing Apple PowerMac G4 Cube Modem, Outer Case: step 1, image 1 of 3 Installing Apple PowerMac G4 Cube Modem, Outer Case: step 1, image 2 of 3 Installing Apple PowerMac G4 Cube Modem, Outer Case: step 1, image 3 of 3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Installing Apple PowerMac G4 Cube Modem: step 2, image 1 of 2 Installing Apple PowerMac G4 Cube Modem: step 2, image 2 of 2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Installing Apple PowerMac G4 Cube Modem: step 3, image 1 of 1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Installing Apple PowerMac G4 Cube Modem: step 4, image 1 of 1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Installing Apple PowerMac G4 Cube Modem, Video Card: step 5, image 1 of 1
    • Remove the screws on the back of the VGA port.
  6. Installing Apple PowerMac G4 Cube Modem: step 6, image 1 of 1
    • Remove the screw attaching the video card to the logic board.
  7. Installing Apple PowerMac G4 Cube Modem: step 7, image 1 of 2 Installing Apple PowerMac G4 Cube Modem: step 7, image 2 of 2
    • Remove power cord from the video card.
  8. Installing Apple PowerMac G4 Cube Modem: step 8, image 1 of 1
    • Remove the power cord.
    • Remove the connector.
    • Remove the video card from the logic board.
  9. Installing Apple PowerMac G4 Cube Modem: step 9, image 1 of 1
    • Carefully lift the video card from the logic board.
    • The video card should come out easily.
  10. Installing Apple PowerMac G4 Cube Modem: step 10, image 1 of 2 Installing Apple PowerMac G4 Cube Modem: step 10, image 2 of 2
    • Separate the video card from the adapter.
  11. Installing Apple PowerMac G4 Cube Modem, Modem: step 11, image 1 of 1
    • Remove the two screws from the modem.
  12. Installing Apple PowerMac G4 Cube Modem: step 12, image 1 of 1
    • Lift modem from the Logic Board.
    • The modem should come out easily.
Ryan Chun
1,076 Reputation
7 Guides authored
Cal Poly, Team 2-7, Johann Summer 2010 Member of Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 4,146
