Power Mac G4 Cube Airport Card Replacement
  1. Power Mac G4 Cube Airport Card Replacement, Outer Case: step 1, image 1 of 3 Power Mac G4 Cube Airport Card Replacement, Outer Case: step 1, image 2 of 3 Power Mac G4 Cube Airport Card Replacement, Outer Case: step 1, image 3 of 3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Airport Card Replacement: step 2, image 1 of 2 Power Mac G4 Cube Airport Card Replacement: step 2, image 2 of 2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Airport Card Replacement: step 3, image 1 of 1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Airport Card Replacement: step 4, image 1 of 1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: step 5, image 1 of 2 Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: step 5, image 2 of 2
    • Pull outwards on the antenna cable.
    • Pull on the clear tab outwards to remove the existing AirPort card
    • Slide in the new AirPort card and connect the antenna cable
Ryan Chun
1,076 Reputation
7 Guides authored
Cal Poly, Team 2-7, Johann Summer 2010 Member of Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 9,882
