Power Cord Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Power Cord Removal, Safety precautions: step 1, image 1 of 1
      • Before you begin, ensure the device is powered down and cool to the touch.
      • Ensure the machine is unplugged.
      • Turn the power switch counterclockwise into the OFF position.
      Ask FixBot
    1. Power Cord Removal, Unwrap the power cord: step 2, image 1 of 3 Power Cord Removal, Unwrap the power cord: step 2, image 2 of 3 Power Cord Removal, Unwrap the power cord: step 2, image 3 of 3
      • Unwrap the power cord from the device completely.
      Ask FixBot
    2. Power Cord Removal, Remove the on/off lever screw: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove the screw securing the red on/off lever.
      Ask FixBot
    3. Power Cord Removal, Remove the lever: step 4, image 1 of 2 Power Cord Removal, Remove the lever: step 4, image 2 of 2
      • Remove the red lever from the on/off switch.
      Ask FixBot
    4. Power Cord Removal: step 5, image 1 of 2 Power Cord Removal: step 5, image 2 of 2
      • Remove the black plastic cap from the center of the switch assembly.
      Ask FixBot
    5. Power Cord Removal: step 6, image 1 of 1
      • Use a Phillips screwdriver to remove the two screws securing the yellow switch guide to the switch assembly.
      • During reassembly, ensure this component is installed in the same orientation, with the circle in the 6 o'clock "OFF" position.
      Ask FixBot
    6. Power Cord Removal: step 7, image 1 of 3 Power Cord Removal: step 7, image 2 of 3 Power Cord Removal: step 7, image 3 of 3
      • Remove the yellow switch guide from the switch assembly.
      • Remove the black plastic spacer from underneath the yellow switch guide.
      Ask FixBot
    7. Power Cord Removal, Remove the on/off switch housing: step 8, image 1 of 1
      • Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
      Ask FixBot
    8. Power Cord Removal: step 9, image 1 of 3 Power Cord Removal: step 9, image 2 of 3 Power Cord Removal: step 9, image 3 of 3
      • Lift the upper half of the housing straight up off of the lower half.
      Ask FixBot
    9. Power Cord Removal, Remove the power cord: step 10, image 1 of 1
      • Use a 3/8 inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
      Ask FixBot
    10. Power Cord Removal: step 11, image 1 of 3 Power Cord Removal: step 11, image 2 of 3 Power Cord Removal: step 11, image 3 of 3
      • Remove the loom clamp from the power cord.
      Ask FixBot
    11. Power Cord Removal: step 12, image 1 of 3 Power Cord Removal: step 12, image 2 of 3 Power Cord Removal: step 12, image 3 of 3
      • Use a 11/32 inch socket to remove the four nuts from the on/off switch bracket.
      • During reassembly, use a Phillips screwdriver in combination with the 11/32 inch socket wrench to tighten the bolts securing the switch to the bracket.
      Ask FixBot
    12. Power Cord Removal: step 13, image 1 of 2 Power Cord Removal: step 13, image 2 of 2
      • Lift the switch assembly off the switch bracket.
      Ask FixBot
    13. Power Cord Removal: step 14, image 1 of 2 Power Cord Removal: step 14, image 2 of 2
      • Use a flathead screwdriver to remove the screw securing the two green ground wires to the switch housing.
      Ask FixBot
    14. Power Cord Removal: step 15, image 1 of 3 Power Cord Removal: step 15, image 2 of 3 Power Cord Removal: step 15, image 3 of 3
      • Separate the green wires from each other and move them away from the switch housing.
      Ask FixBot
    15. Power Cord Removal: step 16, image 1 of 2 Power Cord Removal: step 16, image 2 of 2
      • Use a flathead screwdriver to loosen the two screws securing the black and white wires running from the power cord to the switch.
      • During reassembly, ensure each wire in installed in its correct location on the switch.
      Ask FixBot
    16. Power Cord Removal: step 17, image 1 of 3 Power Cord Removal: step 17, image 2 of 3 Power Cord Removal: step 17, image 3 of 3
      • Remove the black wire from the switch.
      Ask FixBot
    17. Power Cord Removal: step 18, image 1 of 3 Power Cord Removal: step 18, image 2 of 3 Power Cord Removal: step 18, image 3 of 3
      • Remove the white wire from the switch.
      Ask FixBot
    18. Power Cord Removal: step 19, image 1 of 3 Power Cord Removal: step 19, image 2 of 3 Power Cord Removal: step 19, image 3 of 3
      • Use a 1-1/16 inch wrench or an adjustable wrench to loosen the power cord's strain relief fitting from the switch housing.
      • Once the fitting is loose enough to turn by hand, twist the power cord and fitting counterclockwise until it is fully unthreaded from the switch housing.
      Ask FixBot
    19. Power Cord Removal: step 20, image 1 of 3 Power Cord Removal: step 20, image 2 of 3 Power Cord Removal: step 20, image 3 of 3
      • Remove the power cord from the switch.
      Ask FixBot
Sam Omiotek
100,863 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 10
All Time: 175
