Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Spudger4.9
Use the point of a spudger to push on alternating sides of the copper cable's connector until it slides fully into the socket on the underside of the power board.
Flip the power board over and slide it into its recess, making sure the three cables that connect to the charging port don't get stuck underneath.
Make sure the three cables are oriented so they can connect to the board.
The gold speaker contacts should be sitting in their small groove.
Check that each screw has its rubber gasket installed.
Use a Torx Plus 3IP screwdriver to install the two 5.7 mm‑long screws securing the power board.
Use your finger to press down and reconnect the three power board press connectors.
Put the connector cover into place on the center of the power board.
