Installing an Iron-on Patch
  1. Installing an Iron-on Patch, Installing an Iron-on Patch: step 1, image 1 of 2 Installing an Iron-on Patch, Installing an Iron-on Patch: step 1, image 2 of 2
    • Examine the damage – cut off any long threads and clean off any debris.
    • Grab your iron-on patch.
    • We are using a contrasting patch for visibility, but you may want something that matches with your jeans or a fun contrasting color.
    Ask FixBot
  2. Installing an Iron-on Patch: step 2, image 1 of 3 Installing an Iron-on Patch: step 2, image 2 of 3 Installing an Iron-on Patch: step 2, image 3 of 3
    • Preheat your iron according to the recommended settings found on the packaging information included with the patch.
    • Take a scrap of denim and place it inside the pant leg, beneath the hole.
    • This scrap material will keep your patch from sticking the front of your jeans to the back, which would effectively seal the leg opening shut (not a good thing...)
    Ask FixBot
  3. Installing an Iron-on Patch: step 3, image 1 of 2 Installing an Iron-on Patch: step 3, image 2 of 2
    • Measure the length and width of the hole in your jeans, including any damaged area around the hole.
    • In our case the hole is about 1.5 inches by 2 inches.
    Ask FixBot
  4. Installing an Iron-on Patch: step 4, image 1 of 2 Installing an Iron-on Patch: step 4, image 2 of 2
    • Add at least a half-inch in both directions to get your final patch measurements.
    • Mark your final patch measurements on the patch with tailor’s chalk.
    Ask FixBot
  5. Installing an Iron-on Patch: step 5, image 1 of 2 Installing an Iron-on Patch: step 5, image 2 of 2
    • Cut the patch along your marks.
    • Round the corners of the patch, to prevent them from peeling up.
    Ask FixBot
  6. Installing an Iron-on Patch: step 6, image 1 of 3 Installing an Iron-on Patch: step 6, image 2 of 3 Installing an Iron-on Patch: step 6, image 3 of 3
    • Lay your cut patch over the hole and position it where you want it.
    Ask FixBot
  7. Installing an Iron-on Patch: step 7, image 1 of 2 Installing an Iron-on Patch: step 7, image 2 of 2
    • Iron the patch according to the package instructions, usually from between 30-45 seconds. Keep the iron moving and try to apply even heat to the whole patch.
    Ask FixBot
  8. Installing an Iron-on Patch: step 8, image 1 of 2 Installing an Iron-on Patch: step 8, image 2 of 2
    • Run your finger around the edge of the patch to ensure that all the edges are completely bonded to your jeans.
    Ask FixBot
  9. Installing an Iron-on Patch: step 9, image 1 of 3 Installing an Iron-on Patch: step 9, image 2 of 3 Installing an Iron-on Patch: step 9, image 3 of 3
    • Turn the pant leg inside out.
    • Gently try and lift the scrap of fabric from the inside of the pant leg.
    • If the scrap comes off, you no longer need it.
    • If the scrap is held firmly in place by the patch, simply trim away the excess fabric from where the scrap is adhered with your scissors, leaving the remaining scrap in place.
    Ask FixBot
Admire your work!
20 other people completed this guide.
Brittany McCrigler
90,933 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
122 Members
26,593 Guides authored
5 Guide Comments
This is useful, but I hope we can see more. In particular, my kids have many holes in polar fleece pants that they love. You can't do an iron-on patch with fleece (the synthetic fiber can't take the heat), and sewing on a patch doesn't seem like a great idea since the material is stretchier than the patch. Does Patagonia have advice on how to repair these?
Raphael Sperry - Reply Share
Just a little video I put together how your your step by step procedure in video formats is done Hope it helps https://m.youtube.com/watch?v=T9iCnIr5Su...
ristuccia.daniel - Reply Share
what we men need is some way to fix pockets….. that flimsy stuff wears through in no time…
abrogard - Reply Share
Instead of a scrap piece of denim, I put another patch on the inside and iron them together.
Ken Eisman - Reply Share
Nice instructions for patching jeans, but need a video on how to patch a hole in a fleece jacket. Guessing we can't just put a denim patch on fleece material, as ironing would melt the fleece. Would love suggestions.
Thanks!
leslie.herrmann1@gmail.com - Reply Share
Past 24 Hours: 16
Past 7 Days: 191
Past 30 Days: 968
All Time: 246,195
