Shop the Holiday Gift Guide
Porter-Cable PC60TAG Power Switch Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
94
All Time:
1,390
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
Often times, a grinder that won't power on is due to a faulty power switch. This mechanical part may fail over time, resulting in the need to replace it. Use this guide to replace the power switch in your Porter-Cable PC60TAG.
Tools
    1. Porter-Cable PC60TAG Power Switch Replacement, Power Switch: step 1, image 1 of 1
      • Using the Phillips #2 screwdriver, remove the 3/4" Phillips screw on the back cover.
      • Unplug the grinder before disassembling.
      Ask FixBot
    2. Porter-Cable PC60TAG Power Switch Replacement: step 2, image 1 of 1
      • Holding the front of the device, carefully slide the back cover over the cord.
      Ask FixBot
    3. Porter-Cable PC60TAG Power Switch Replacement: step 3, image 1 of 1
      • Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
      Ask FixBot
    4. Porter-Cable PC60TAG Power Switch Replacement: step 4, image 1 of 1
      • Careful remove each wire from the power cord from underneath the terminals.
      Ask FixBot
    5. Porter-Cable PC60TAG Power Switch Replacement: step 5, image 1 of 1
      • Using the spudger, carefully push the red power switch out of the device.
      Ask FixBot
    6. Porter-Cable PC60TAG Power Switch Replacement: step 6, image 1 of 1
      • From the other side of the device, use the spudger to carefully pry out power switch away from the device.
      Ask FixBot
    7. Porter-Cable PC60TAG Power Switch Replacement: step 7, image 1 of 1
      • Using your fingers, carefully remove each of the gold terminals from the power switch. You may need to gently wiggle the terminal back and forth in order to remove it.
      Ask FixBot
Author
with
Mackenzie Fairbanks
591 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 94
All Time: 1,390
