Polaroid SNAP Paper Door Replacement
  1. Polaroid SNAP Paper Door Replacement, Paper Door: step 1, image 1 of 1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Paper Door Replacement: step 2, image 1 of 2 Polaroid SNAP Paper Door Replacement: step 2, image 2 of 2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
  3. Polaroid SNAP Paper Door Replacement: step 3, image 1 of 2 Polaroid SNAP Paper Door Replacement: step 3, image 2 of 2
    • Turn rear face plate over.
  4. Polaroid SNAP Paper Door Replacement: step 4, image 1 of 3 Polaroid SNAP Paper Door Replacement: step 4, image 2 of 3 Polaroid SNAP Paper Door Replacement: step 4, image 3 of 3
    • Maneuver the plastic paper door out of the sockets one at a time. Make sure to be gentle so the plastic does not snap. Also, make sure to keep track of the small springs.
Ian Colantuoni
619 Reputation
2 Guides authored
USF Tampa, Team 7-3, Cheng Spring 2016 Member of USF Tampa, Team 7-3, Cheng Spring 2016
USFT-CHENG-S16S7G3
4 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 40
All Time: 6,841
