Polaroid Onestep Close Up Primary Lens Replacement
  1. Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: step 1, image 1 of 3 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: step 1, image 2 of 3 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: step 1, image 3 of 3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: step 2, image 1 of 2 Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: step 2, image 2 of 2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: step 3, image 1 of 3 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: step 3, image 2 of 3 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: step 3, image 3 of 3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Primary Lens Replacement, Primary Lens: step 4, image 1 of 1
    • Once the front assembly is removed, the primary lens should be exposed without any trouble.
  5. Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: step 5, image 1 of 2 Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: step 5, image 2 of 2
    • Use your spudger to leverage the lens from the groove at the top (red).
    • Pry the lens loose. It may pop out, so have a method in place to prevent it from dropping.
Christopher Collazo
318 Reputation
2 Guides authored
USF Tampa, Team 3-5, Brown Fall 2014 Member of USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 1,438
