Polaroid Flash Unit Shell Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
65
All Time:
560
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Use this guide to replace, change, or upgrade the flash unit shell (aka flash shell, flash cover, front cover, or flip cover) on your Polaroid Flip instant camera.
You may want to change the flash unit shell if it's cracked or damaged, or if you want to customize your camera with different colors.
Tools
    1. Polaroid Flash Unit Shell Replacement, Before you begin: step 1, image 1 of 1
      • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
      • Unplug all cables from your camera.
      Ask FixBot
    2. Polaroid Flash Unit Shell Replacement, Open your camera: step 2, image 1 of 2 Polaroid Flash Unit Shell Replacement, Open your camera: step 2, image 2 of 2
      • Fully open the flash unit at the front of your camera.
      Ask FixBot
    3. Polaroid Flash Unit Shell Replacement, Remove the screw cover: step 3, image 1 of 3 Polaroid Flash Unit Shell Replacement, Remove the screw cover: step 3, image 2 of 3 Polaroid Flash Unit Shell Replacement, Remove the screw cover: step 3, image 3 of 3
      • Slide the tip of an opening pick under the right edge of the screw cover, near the flash.
      • Leave the pick inserted under the cover for the next step.
      Ask FixBot
    4. Polaroid Flash Unit Shell Replacement: step 4, image 1 of 3 Polaroid Flash Unit Shell Replacement: step 4, image 2 of 3 Polaroid Flash Unit Shell Replacement: step 4, image 3 of 3
      • Slide the cover towards the flash to release the clips securing it.
      • Your pick might fall out—that's fine.
      • Pull the cover straight away from the camera and remove it.
      Ask FixBot
    5. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: step 5, image 1 of 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: step 5, image 2 of 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: step 5, image 3 of 3
      • Hold the flash unit open with one hand.
      • With your free hand, use a Phillips screwdriver to remove the three 5.9 mm‑long screws securing the flash unit shell.
      Ask FixBot
    6. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: step 6, image 1 of 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: step 6, image 2 of 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: step 6, image 3 of 3
      • Fully close the flash unit for a better grip on the shell.
      • Secure the camera with one hand, and firmly grip the flash unit shell with the other.
      • Lift the right edge of the shell (the side closest to the charging port) to release the clips securing it.
      • You should feel and hear "clicks" as the clips release.
      • Pull the shell up and away from the camera to remove it.
      • During reassembly, put the shell in place and push down firmly to engage the clips.
      Ask FixBot
Spencer Day
208,115 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 65
All Time: 560
