Polaroid Cube Lens Replacement
    1. Polaroid Cube Lens Replacement, Battery: step 1, image 1 of 1
      • Remove the SD card cover by twisting it using a Plastic Opening Tool
      Ask FixBot
    2. Polaroid Cube Lens Replacement: step 2, image 1 of 1
      • Use the Plastic Opening tool to pry off and remove the front cover.
      Ask FixBot
    3. Polaroid Cube Lens Replacement: step 3, image 1 of 1
      • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
      Ask FixBot
    4. Polaroid Cube Lens Replacement: step 4, image 1 of 2 Polaroid Cube Lens Replacement: step 4, image 2 of 2
      • Use the Plastic Opening Tool to pry open the shell of the camera.
      • There are four latches, one at each corner, that you will need to detach.
      Ask FixBot
    5. Polaroid Cube Lens Replacement: step 5, image 1 of 1
      • Remove shell from top and bottom of camera.
      Ask FixBot
    6. Polaroid Cube Lens Replacement: step 6, image 1 of 1
      • Remove the rubber seal wrapped around the camera.
      Ask FixBot
    7. Polaroid Cube Lens Replacement: step 7, image 1 of 2 Polaroid Cube Lens Replacement: step 7, image 2 of 2
      • Remove the tape wrapped around the battery.
      Ask FixBot
    8. Polaroid Cube Lens Replacement: step 8, image 1 of 3 Polaroid Cube Lens Replacement: step 8, image 2 of 3 Polaroid Cube Lens Replacement: step 8, image 3 of 3
      • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
      Ask FixBot
    9. Polaroid Cube Lens Replacement: step 9, image 1 of 2 Polaroid Cube Lens Replacement: step 9, image 2 of 2
      • Use the plastic opening tool to remove the circuit board that the battery is connected to.
      Ask FixBot
    10. Polaroid Cube Lens Replacement: step 10, image 1 of 1
      • Gently remove the battery pin connector from the circuit board.
      Ask FixBot
    1. Polaroid Cube Lens Replacement, Lens: step 11, image 1 of 2 Polaroid Cube Lens Replacement, Lens: step 11, image 2 of 2
      • Use a J00 screwdriver to unscrew the two circled 3.5mm Phillips-head screws from the circuit board.
      Ask FixBot
    2. Polaroid Cube Lens Replacement: step 12, image 1 of 2 Polaroid Cube Lens Replacement: step 12, image 2 of 2
      • Use a J00 head screwdriver to unscrew the two 3.5mm screws from the circuit board.
      Ask FixBot
    3. Polaroid Cube Lens Replacement: step 13, image 1 of 1
      • Remove the lens from the unscrewed circuit board and replace the broken lens.
      Ask FixBot
4 other people completed this guide.
Grant Baldwin
685 Reputation
2 Guides authored
IUPUI, Team 3-2, Harley Fall 2016 Member of IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 Members
36 Guides authored
2 Guide Comments
Where can I find a replacement lens for the cube+? I broke the bubble part of the lens
Ben McAlister - Reply Share
Maybe is posable replace wider view angle lens ? original looks like fpv camera lens foxeer or runcam micro. Possibly Caddx micro cam lens
starsas777 - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 57
All Time: 2,783
