Polaroid Cube Battery Replacement
  1. Polaroid Cube Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Battery Replacement: step 2, image 1 of 1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Battery Replacement: step 3, image 1 of 1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Battery Replacement: step 4, image 1 of 2 Polaroid Cube Battery Replacement: step 4, image 2 of 2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Battery Replacement: step 5, image 1 of 1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Battery Replacement: step 6, image 1 of 1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Battery Replacement: step 7, image 1 of 2 Polaroid Cube Battery Replacement: step 7, image 2 of 2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Battery Replacement: step 8, image 1 of 3 Polaroid Cube Battery Replacement: step 8, image 2 of 3 Polaroid Cube Battery Replacement: step 8, image 3 of 3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Battery Replacement: step 9, image 1 of 2 Polaroid Cube Battery Replacement: step 9, image 2 of 2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Battery Replacement: step 10, image 1 of 1
    • Gently remove the battery pin connector from the circuit board.
heath lamkin
372 Reputation
1 Guide authored
IUPUI, Team 3-2, Harley Fall 2016 Member of IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 Members
3 Guides authored
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 46
All Time: 9,308
