Polaroid A10 Speakers Replacement
  1. Polaroid A10 Speakers Replacement, Back Cover: step 1, image 1 of 3 Polaroid A10 Speakers Replacement, Back Cover: step 1, image 2 of 3 Polaroid A10 Speakers Replacement, Back Cover: step 1, image 3 of 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Speakers Replacement, Speakers: step 2, image 1 of 1
    • The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
  3. Polaroid A10 Speakers Replacement: step 3, image 1 of 3 Polaroid A10 Speakers Replacement: step 3, image 2 of 3 Polaroid A10 Speakers Replacement: step 3, image 3 of 3
    • Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
    • Carefully remove the speakers from original position without pulling out the wires.
  4. Polaroid A10 Speakers Replacement: step 4, image 1 of 1
    • Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
    • The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Speakers Replacement: step 5, image 1 of 1
    • Gently lift the speakers up and out of the device.
Koby
104 Reputation
1 Guide authored
UW Tacoma, Team 3-3, Rose Winter 2015 Member of UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Members
12 Guides authored
3 Comments
This is not what I meant I wanted to know what to do if the wires came out of the
amirahoresanwo - Reply
If the wires and out of the
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 231
