Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
Tool used on this step:Tweezers$4.99
Use tweezers to gently pry the golden sensor away from the battery.
Remove battery using the plastic opening tools.
Thanks, very clear straight forward steps
this shows how to take the battery out; what about replacing it nd securign the ‘electricity leads’ of the new battery to the watch?
même remaque que jonathan
pas assez de précision sur la remise en place des connecteur de la nouvelle batterie
Bonjour François, as tu réussi à remonter la batterie?
It says 'To reassemble your device, follow these instructions in reverse order' How difficult is that? So, put battery in, carefully fold contacts back, etc, etc....if that is not obvious, then please do not attempt this at all.
Make sure that the charging port remains accessible, as it can easily become detached during the replacement.
hello and thanks for the tutorial. I need to fix the screen of a V800 polar and I have a screen of the m400. Do you think I can replace one with the other? Can you confirm what the same LCD is? Thank you very much for everything
Where does even one get a screen in the first place?
Bonjour,
pouvez-vous me dire ou acheter un port usb pour remplacer sur montre M400 comme expliqué sur le tutoriel?
Merci
Denis
5 other people completed this guide.
10 Comments
Hi, where can i buy the replacement?
Thanks
hi,where can I buy the usb replacement.
Hi, were can i buy the replacement. Thanks
I bought a connector USB there… Maybe can be interesting for someone else…
hello manuel,
i tried to order from the web site you specified, but it looks like they are not delivering in france,
cna you please tell me where else i can order this peice
Polar won’t sell spare parts so where can I buy a replacement screen or a replacement front case for the M430?
hello olivier,
did u find a resellor for polar spare pieces , i am looking for usb connector fo m400
I destroyed the micro usb port on my watch (don’t ask..) I bought another used m400 for a very cheap price, because the screen protector was messed up - full of scratches. I switched the insides of the watches using your instructions. Thank you! I now have a working watch with a clean screen protector and an extra battery just in case I need one later.
I damaged the star screw (STEP 4). What type is it? Where can I buy these star screws? well thank you
Hi
where can i get a polar M400 Screen protector in Cape Town.
It may be easier to push the pins out in one direction. Unfortunately, I do not recall which direction was easier…
Nathan Gelderloos - Reply
