Introduction
This guide shows how to replace a defective battery from a Poin2 Chromebook 11, remove the battery to test the device's power adapter, or remove the battery in order to access another component.
Power down the Poin2 Chromebook 11 and disconnect the power adapter.
Close the Chromebook and position it with the base facing up.
Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
To reassemble your Poin2 Chromebook 11, follow these instructions in reverse order.
2 other people completed this guide.
One Comment
An important piece of information missing is the battery replacement number.
a Google search brings up no references.
Rubber feet at the base DO have screws. I broke mine not knowing this.
Marty - Reply
