Shop the Holiday Gift Guide
Playstation 3 Optical Drive Replacement
Views: 7.7K
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
28
All Time:
7,715
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide explains how to take apart the Sony PlayStation 3 optical drive. These steps are useful for repairing or replacing the optical drive.
Tools
    1. Playstation 3 Optical Drive Replacement, Top Cover: step 1, image 1 of 2 Playstation 3 Optical Drive Replacement, Top Cover: step 1, image 2 of 2
      • Remove the rubber screw cover near the hard drive cover with a spudger.
      Ask FixBot
    2. Playstation 3 Optical Drive Replacement: step 2, image 1 of 1
      • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
      Ask FixBot
    3. Playstation 3 Optical Drive Replacement: step 3, image 1 of 2 Playstation 3 Optical Drive Replacement: step 3, image 2 of 2
      • Slide the top cover down about half an inch.
      • Lift the cover off of the PS3.
      Ask FixBot
    4. Playstation 3 Optical Drive Replacement: step 4, image 1 of 2 Playstation 3 Optical Drive Replacement: step 4, image 2 of 2
      • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
      • One of the screws is shorter than the others. The short screw is marked in yellow.
      Ask FixBot
    5. Playstation 3 Optical Drive Replacement: step 5, image 1 of 3 Playstation 3 Optical Drive Replacement: step 5, image 2 of 3 Playstation 3 Optical Drive Replacement: step 5, image 3 of 3
      • You can now lift off the top cover.
      Ask FixBot
    1. Playstation 3 Optical Drive Replacement, Optical Drive: step 6, image 1 of 3 Playstation 3 Optical Drive Replacement, Optical Drive: step 6, image 2 of 3 Playstation 3 Optical Drive Replacement, Optical Drive: step 6, image 3 of 3
      • Lift the optical drive enclosure and disconnect the grey wires.
      • Do not lift it too far up before disconnecting the wires.
      Ask FixBot
    2. Playstation 3 Optical Drive Replacement: step 7, image 1 of 3 Playstation 3 Optical Drive Replacement: step 7, image 2 of 3 Playstation 3 Optical Drive Replacement: step 7, image 3 of 3
      • Tilt the front of the optical drive enslosure upwards.
      • Lift the black ribbon cable latch on the back side with your finger or a spudger.
      • Disconnect the ribbon cable.
      Ask FixBot
    3. Playstation 3 Optical Drive Replacement: step 8, image 1 of 1
      • Remove the optical drive enclosure from the PS3.
      Ask FixBot
    4. Playstation 3 Optical Drive Replacement: step 9, image 1 of 3 Playstation 3 Optical Drive Replacement: step 9, image 2 of 3 Playstation 3 Optical Drive Replacement: step 9, image 3 of 3
      • Flip over the optical drive enclosure. There are four ribbon cables connected to the circuit board. Using a spudger or your finger, lift each ribbon cable latch and disconnect each ribbon cable.
      • Remove the three screws on the board with a Phillips #00 screwdriver.
      • Remove the two silver screws on the bottom of the case. These screws are different from the ones on the board and should be kept separate.
      • Note: The longer of these two screws holds down a metal tab that comes loose as seen in the third picture.
      Ask FixBot
    5. Playstation 3 Optical Drive Replacement: step 10, image 1 of 2 Playstation 3 Optical Drive Replacement: step 10, image 2 of 2
      • Using your thumbs, carefully bend out the sides of the metal enclosure.
      • Lift the plastic enclosure out of the metal enclosure.
      Ask FixBot
    6. Playstation 3 Optical Drive Replacement: step 11, image 1 of 3 Playstation 3 Optical Drive Replacement: step 11, image 2 of 3 Playstation 3 Optical Drive Replacement: step 11, image 3 of 3
      • Flip over the enclosure so that the circuit board is on the bottom and the optical sensor is on top.
      • Remove the screw on the optical sensor using a Phillips #00 screwdriver.
      • Remove the tape on the red and black wires that connect to the optical sensor. With the wires still attached, take the sensor off the ensclosure.
      • The wires on the optical sensor are very weak. They will break easily if excessive force is applied to them.
      • Remove the four black screws on the edges of the enclosure using a Phillips #00 screwdriver.
      • After taking out the screws, you don't have to open the enclosure just yet.
      Ask FixBot
    7. Playstation 3 Optical Drive Replacement: step 12, image 1 of 2 Playstation 3 Optical Drive Replacement: step 12, image 2 of 2
      • Flip over the enclosure again.
      • Remove the rest of the screws in the corners of the circuit board.
      Ask FixBot
    8. Playstation 3 Optical Drive Replacement: step 13, image 1 of 3 Playstation 3 Optical Drive Replacement: step 13, image 2 of 3 Playstation 3 Optical Drive Replacement: step 13, image 3 of 3
      • Lift the circuit board off the enclosure.
      • The metal EM shield on the circuit board is loose, so make sure to keep it together with the circuit board.
      • Remove the metal plate.
      Ask FixBot
    9. Playstation 3 Optical Drive Replacement: step 14, image 1 of 2 Playstation 3 Optical Drive Replacement: step 14, image 2 of 2
      • Flip over the enclosure. Remove the black, plastic cover so that the drive and its enclosure match the first picture.
      • Proceed carefully. There are loose parts inside the optical drive. We recommend that you tape these parts.
      Ask FixBot
    10. Playstation 3 Optical Drive Replacement: step 15, image 1 of 2 Playstation 3 Optical Drive Replacement: step 15, image 2 of 2
      • Using a spudger, lift the brown latch and disconnect the small ribbon cable.
      • Remove the four fat screws in the corners of the optical drive.
      • Using a spudger, lift the black latch and disconnect the larger ribbon cable.
      Ask FixBot
    11. Playstation 3 Optical Drive Replacement: step 16, image 1 of 2 Playstation 3 Optical Drive Replacement: step 16, image 2 of 2
      • Carefully lift the optical drive out of the enclosure.
      Ask FixBot
2 other people completed this guide.
Author
with
iDeleted
2,101 Reputation
39 Guides authored
1 Guide Comment
When reassembling it there is a key part that needs to be exactly inline. see this video for help: http://www.youtube.com/watch?v=hzHPRGHFj...
Paddy - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 28
All Time: 7,715
