Shop the Holiday Gift Guide
Playstation 3 Fan Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
47
All Time:
3,069
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Community-Contributed Guide
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
The whole Playstation 3 is cooled by a single fan on its bottom side. In this guide, we will remove that fan so that it may be cleaned or replaced.
Tools
    1. Playstation 3 Fan Replacement, Top Cover: step 1, image 1 of 2 Playstation 3 Fan Replacement, Top Cover: step 1, image 2 of 2
      • Remove the rubber screw cover near the hard drive cover with a spudger.
      Ask FixBot
    2. Playstation 3 Fan Replacement: step 2, image 1 of 1
      • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
      Ask FixBot
    3. Playstation 3 Fan Replacement: step 3, image 1 of 2 Playstation 3 Fan Replacement: step 3, image 2 of 2
      • Slide the top cover down about half an inch.
      • Lift the cover off of the PS3.
      Ask FixBot
    4. Playstation 3 Fan Replacement: step 4, image 1 of 2 Playstation 3 Fan Replacement: step 4, image 2 of 2
      • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
      • One of the screws is shorter than the others. The short screw is marked in yellow.
      Ask FixBot
    5. Playstation 3 Fan Replacement: step 5, image 1 of 3 Playstation 3 Fan Replacement: step 5, image 2 of 3 Playstation 3 Fan Replacement: step 5, image 3 of 3
      • You can now lift off the top cover.
      Ask FixBot
    1. Playstation 3 Fan Replacement, Power Supply: step 6, image 1 of 2 Playstation 3 Fan Replacement, Power Supply: step 6, image 2 of 2
      • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
      • Push down the tab on the connector to disconnect the wires.
      • Remove the two screws on the front of the power supply.
      Ask FixBot
    2. Playstation 3 Fan Replacement: step 7, image 1 of 1
      • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
      Ask FixBot
    3. Playstation 3 Fan Replacement: step 8, image 1 of 2 Playstation 3 Fan Replacement: step 8, image 2 of 2
      • Remove the power supply by lifting it straight up.
      Ask FixBot
    1. Playstation 3 Fan Replacement, Motherboard Enclosure: step 9, image 1 of 2 Playstation 3 Fan Replacement, Motherboard Enclosure: step 9, image 2 of 2
      • Unplug the optical drive power cable.
      • Detach the ribbon cable that connects the optical drive to the motherboard.
      • Set the optical drive aside.
      Ask FixBot
    2. Playstation 3 Fan Replacement: step 10, image 1 of 2 Playstation 3 Fan Replacement: step 10, image 2 of 2
      • Remove three screws (Phillips #2) from the wireless board and antenna.
      • Detach the ribbon cable that connects the wireless board to the motherboard.
      Ask FixBot
    3. Playstation 3 Fan Replacement: step 11, image 1 of 1
      • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
      Ask FixBot
    4. Playstation 3 Fan Replacement: step 12, image 1 of 3 Playstation 3 Fan Replacement: step 12, image 2 of 3 Playstation 3 Fan Replacement: step 12, image 3 of 3
      • Remove the hard drive door with a spudger.
      • Lift the metal enclosure out of the plastic bottom case.
      Ask FixBot
    1. Playstation 3 Fan Replacement, Fan: step 13, image 1 of 1
      • Remove the three screws (Phillips #2).
      • Disconnect the fan's power cable.
      • Lift the fan straight up and out.
      Ask FixBot
Author
with
iDeleted
2,101 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 47
All Time: 3,069
