PlayStation Vita Rear Panel Replacement
  1. PlayStation Vita Rear Panel Replacement, Case Separation: step 1, image 1 of 2 PlayStation Vita Rear Panel Replacement, Case Separation: step 1, image 2 of 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Rear Panel Replacement: step 2, image 1 of 3 PlayStation Vita Rear Panel Replacement: step 2, image 2 of 3 PlayStation Vita Rear Panel Replacement: step 2, image 3 of 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Rear Panel Replacement: step 3, image 1 of 2 PlayStation Vita Rear Panel Replacement: step 3, image 2 of 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Rear Panel Replacement: step 4, image 1 of 3 PlayStation Vita Rear Panel Replacement: step 4, image 2 of 3 PlayStation Vita Rear Panel Replacement: step 4, image 3 of 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Rear Panel Replacement: step 5, image 1 of 2 PlayStation Vita Rear Panel Replacement: step 5, image 2 of 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Rear Panel Replacement: step 6, image 1 of 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Rear Panel Replacement: step 7, image 1 of 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Rear Panel Replacement: step 8, image 1 of 1
    • Separate the front and rear cases.
  9. PlayStation Vita Rear Panel Replacement, Battery: step 9, image 1 of 2 PlayStation Vita Rear Panel Replacement, Battery: step 9, image 2 of 2
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
  10. PlayStation Vita Rear Panel Replacement: step 10, image 1 of 2 PlayStation Vita Rear Panel Replacement: step 10, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
  11. PlayStation Vita Rear Panel Replacement: step 11, image 1 of 3 PlayStation Vita Rear Panel Replacement: step 11, image 2 of 3 PlayStation Vita Rear Panel Replacement: step 11, image 3 of 3
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
  12. PlayStation Vita Rear Panel Replacement, Rear Panel: step 12, image 1 of 3 PlayStation Vita Rear Panel Replacement, Rear Panel: step 12, image 2 of 3 PlayStation Vita Rear Panel Replacement, Rear Panel: step 12, image 3 of 3
    • Slide the spuder between the right speaker and the rear casing.
    • Using a spudger, gently peel up the right speaker from the light adhesive connecting it to casing.
    • Remove the right speaker.
  13. PlayStation Vita Rear Panel Replacement: step 13, image 1 of 3 PlayStation Vita Rear Panel Replacement: step 13, image 2 of 3 PlayStation Vita Rear Panel Replacement: step 13, image 3 of 3
    • Slide the spudger between the left speaker and the rear casing.
    • Using a spudger, gently peel up the left speaker from the light adhesive connecting it to casing.
    • Remove the left speaker.
  14. PlayStation Vita Rear Panel Replacement: step 14, image 1 of 1
    • The rear panel remains.
Brittany McCrigler
89,020 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,410 Guides authored
Past 24 Hours: 15
Past 7 Days: 83
Past 30 Days: 319
All Time: 30,548
