PlayStation Vita Case Separation
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. PlayStation Vita Case Separation, Case Separation: step 1, image 1 of 2 PlayStation Vita Case Separation, Case Separation: step 1, image 2 of 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Case Separation: step 2, image 1 of 3 PlayStation Vita Case Separation: step 2, image 2 of 3 PlayStation Vita Case Separation: step 2, image 3 of 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Case Separation: step 3, image 1 of 2 PlayStation Vita Case Separation: step 3, image 2 of 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Case Separation: step 4, image 1 of 3 PlayStation Vita Case Separation: step 4, image 2 of 3 PlayStation Vita Case Separation: step 4, image 3 of 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Case Separation: step 5, image 1 of 2 PlayStation Vita Case Separation: step 5, image 2 of 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Case Separation: step 6, image 1 of 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Case Separation: step 7, image 1 of 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Case Separation: step 8, image 1 of 1
    • Separate the front and rear cases.
Brittany McCrigler
89,020 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,275 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 315
