PlayStation VR Processor Unit Cooling Fan Replacement
  1. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: step 1, image 1 of 3 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: step 1, image 2 of 3 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: step 1, image 3 of 3
    • On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
  2. PlayStation VR Processor Unit Cooling Fan Replacement: step 2, image 1 of 3 PlayStation VR Processor Unit Cooling Fan Replacement: step 2, image 2 of 3 PlayStation VR Processor Unit Cooling Fan Replacement: step 2, image 3 of 3
    • Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
    • Unscrew the 6mm screw with a PH #000 screwdriver.
  3. PlayStation VR Processor Unit Cooling Fan Replacement: step 3, image 1 of 2 PlayStation VR Processor Unit Cooling Fan Replacement: step 3, image 2 of 2
    • Slide the panel back into place.
  4. PlayStation VR Processor Unit Cooling Fan Replacement: step 4, image 1 of 3 PlayStation VR Processor Unit Cooling Fan Replacement: step 4, image 2 of 3 PlayStation VR Processor Unit Cooling Fan Replacement: step 4, image 3 of 3
    • Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
    • You will probably need to lift it on both sides in order for the panel to come loose.
  5. PlayStation VR Processor Unit Cooling Fan Replacement: step 5, image 1 of 1
    • Turn the console over.
    • Unscrew the two 9 mm screws with a PH #000 screwdriver.
  6. PlayStation VR Processor Unit Cooling Fan Replacement: step 6, image 1 of 2 PlayStation VR Processor Unit Cooling Fan Replacement: step 6, image 2 of 2
    • With the plastic opening tool, carefully pry the console shell panel free and lift it away.
  7. PlayStation VR Processor Unit Cooling Fan Replacement: step 7, image 1 of 2 PlayStation VR Processor Unit Cooling Fan Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
    • Carefully lift the fan and its wiring from the device.
    • Be mindful of damaging the wires.
    • Take care to keep your fingers away from the fan blades.
8 other people completed this guide.
Sarah Shand
1,996 Reputation
7 Guides authored
USF Tampa, Team S3-G1, Sullivan Spring 2017 Member of USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 Members
14 Guides authored
4 Guide Comments
Where do I get a replacement fan tho?
Ponos King - Reply Share
I think is a 3x3 cm fan, alliexpres has some, but what voltage?
crus - Reply Share
5V is what i have read
Ethan Amos - Share
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
herossuperman - Reply Share
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 117
All Time: 10,555
