PlayStation Optical Drive Replacement
  1. PlayStation Optical Drive Replacement, Open the Console: step 1, image 1 of 1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
  2. PlayStation Optical Drive Replacement: step 2, image 1 of 2 PlayStation Optical Drive Replacement: step 2, image 2 of 2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Optical Drive Replacement, Remove the Optical Drive: step 3, image 1 of 2 PlayStation Optical Drive Replacement, Remove the Optical Drive: step 3, image 2 of 2
    • Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
  4. PlayStation Optical Drive Replacement: step 4, image 1 of 3 PlayStation Optical Drive Replacement: step 4, image 2 of 3 PlayStation Optical Drive Replacement: step 4, image 3 of 3
    • Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
    • You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result.
    • Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
  5. PlayStation Optical Drive Replacement: step 5, image 1 of 2 PlayStation Optical Drive Replacement: step 5, image 2 of 2
    • Lift the optical drive straight up to remove it.
Craig Lloyd
35,519 Reputation
82 Guides authored
Past 24 Hours: 5
Past 7 Days: 106
Past 30 Days: 508
All Time: 62,575
