Sony PlayStation 3 Move Trigger Button Replacement
  1. Sony PlayStation 3 Move Trigger Button Replacement, Battery: step 1, image 1 of 3 Sony PlayStation 3 Move Trigger Button Replacement, Battery: step 1, image 2 of 3 Sony PlayStation 3 Move Trigger Button Replacement, Battery: step 1, image 3 of 3
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
  2. Sony PlayStation 3 Move Trigger Button Replacement: step 2, image 1 of 2 Sony PlayStation 3 Move Trigger Button Replacement: step 2, image 2 of 2
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
  3. Sony PlayStation 3 Move Trigger Button Replacement: step 3, image 1 of 2 Sony PlayStation 3 Move Trigger Button Replacement: step 3, image 2 of 2
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
  4. Sony PlayStation 3 Move Trigger Button Replacement: step 4, image 1 of 3 Sony PlayStation 3 Move Trigger Button Replacement: step 4, image 2 of 3 Sony PlayStation 3 Move Trigger Button Replacement: step 4, image 3 of 3
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  5. Sony PlayStation 3 Move Trigger Button Replacement: step 5, image 1 of 2 Sony PlayStation 3 Move Trigger Button Replacement: step 5, image 2 of 2
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  6. Sony PlayStation 3 Move Trigger Button Replacement: step 6, image 1 of 2 Sony PlayStation 3 Move Trigger Button Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  7. Sony PlayStation 3 Move Trigger Button Replacement: step 7, image 1 of 3 Sony PlayStation 3 Move Trigger Button Replacement: step 7, image 2 of 3 Sony PlayStation 3 Move Trigger Button Replacement: step 7, image 3 of 3
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  8. Sony PlayStation 3 Move Trigger Button Replacement: step 8, image 1 of 2 Sony PlayStation 3 Move Trigger Button Replacement: step 8, image 2 of 2
    • Gently pull on the white piece connecting the battery and the connector.
  9. Sony PlayStation 3 Move Trigger Button Replacement, Motherboard: step 9, image 1 of 3 Sony PlayStation 3 Move Trigger Button Replacement, Motherboard: step 9, image 2 of 3 Sony PlayStation 3 Move Trigger Button Replacement, Motherboard: step 9, image 3 of 3
    • Remove the five 1.2 mm screws from upper portion of the controller.
    • If you are replacing the trigger button, continue to step 13.
  10. Sony PlayStation 3 Move Trigger Button Replacement: step 10, image 1 of 2 Sony PlayStation 3 Move Trigger Button Replacement: step 10, image 2 of 2
    • Remove the two 1.2mm Phillips #1 screws.
  11. Sony PlayStation 3 Move Trigger Button Replacement: step 11, image 1 of 3 Sony PlayStation 3 Move Trigger Button Replacement: step 11, image 2 of 3 Sony PlayStation 3 Move Trigger Button Replacement: step 11, image 3 of 3
    • Cautiously remove the circular white piece at the top without removing the LED inside.
  12. Sony PlayStation 3 Move Trigger Button Replacement: step 12, image 1 of 3 Sony PlayStation 3 Move Trigger Button Replacement: step 12, image 2 of 3 Sony PlayStation 3 Move Trigger Button Replacement: step 12, image 3 of 3
    • Remove the blue strip that is connected to the trigger button from the motherboard.
    • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
  13. Sony PlayStation 3 Move Trigger Button Replacement: step 13, image 1 of 2 Sony PlayStation 3 Move Trigger Button Replacement: step 13, image 2 of 2
    • Remove the trigger button from the controller.
  14. Sony PlayStation 3 Move Trigger Button Replacement: step 14, image 1 of 3 Sony PlayStation 3 Move Trigger Button Replacement: step 14, image 2 of 3 Sony PlayStation 3 Move Trigger Button Replacement: step 14, image 3 of 3
    • Remove the LED light by removing the white strip.
    • If you are replacing the LED light, continue to Step 17.
  15. Sony PlayStation 3 Move Trigger Button Replacement: step 15, image 1 of 2 Sony PlayStation 3 Move Trigger Button Replacement: step 15, image 2 of 2
    • Remove the motherboard from the plastic case.
Abdulaziz Refaei
162 Reputation
1 Guide authored
USF Tampa, Team 3-3, Passmore Fall 2016 Member of USF Tampa, Team 3-3, Passmore Fall 2016
USFT-PASSMORE-F16S3G3
4 Members
8 Guides authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 22
All Time: 2,866
