PlayStation 4 Wi-Fi Antenna Replacement
  1. PlayStation 4 Wi-Fi Antenna Replacement, Flip over the PS4: step 1, image 1 of 1
    • Flip the PS4 upside-down with the back side facing towards you.
  2. PlayStation 4 Wi-Fi Antenna Replacement, Remove the warranty stickers: step 2, image 1 of 3 PlayStation 4 Wi-Fi Antenna Replacement, Remove the warranty stickers: step 2, image 2 of 3 PlayStation 4 Wi-Fi Antenna Replacement, Remove the warranty stickers: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. PlayStation 4 Wi-Fi Antenna Replacement, Remove the plastic screw covers: step 3, image 1 of 2 PlayStation 4 Wi-Fi Antenna Replacement, Remove the plastic screw covers: step 3, image 2 of 2
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. PlayStation 4 Wi-Fi Antenna Replacement, Remove the rear case screws: step 4, image 1 of 2 PlayStation 4 Wi-Fi Antenna Replacement, Remove the rear case screws: step 4, image 2 of 2
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. PlayStation 4 Wi-Fi Antenna Replacement, Remove the lower case: step 5, image 1 of 2 PlayStation 4 Wi-Fi Antenna Replacement, Remove the lower case: step 5, image 2 of 2
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. PlayStation 4 Wi-Fi Antenna Replacement: step 6, image 1 of 2 PlayStation 4 Wi-Fi Antenna Replacement: step 6, image 2 of 2
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • If your connector feels stuck, use a spudger to gently pry the connector out.
  7. PlayStation 4 Wi-Fi Antenna Replacement, Remove the Wi-Fi antenna: step 7, image 1 of 2 PlayStation 4 Wi-Fi Antenna Replacement, Remove the Wi-Fi antenna: step 7, image 2 of 2
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
  8. PlayStation 4 Wi-Fi Antenna Replacement: step 8, image 1 of 3 PlayStation 4 Wi-Fi Antenna Replacement: step 8, image 2 of 3 PlayStation 4 Wi-Fi Antenna Replacement: step 8, image 3 of 3
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
  9. PlayStation 4 Wi-Fi Antenna Replacement: step 9, image 1 of 3 PlayStation 4 Wi-Fi Antenna Replacement: step 9, image 2 of 3 PlayStation 4 Wi-Fi Antenna Replacement: step 9, image 3 of 3
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
  10. PlayStation 4 Wi-Fi Antenna Replacement: step 10, image 1 of 2 PlayStation 4 Wi-Fi Antenna Replacement: step 10, image 2 of 2
    • Remove the 9.7 mm Torx security screw securing the antenna.
Sam Omiotek
74,738 Reputation
288 Guides authored
Past 24 Hours: 33
Past 7 Days: 221
Past 30 Days: 1,045
All Time: 166,858
