PlayStation 4 Pro Power Supply Assembly Guide
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. PlayStation 4 Pro Power Supply Assembly Guide, Hard Drive Caddy: step 1, image 1 of 3 PlayStation 4 Pro Power Supply Assembly Guide, Hard Drive Caddy: step 1, image 2 of 3 PlayStation 4 Pro Power Supply Assembly Guide, Hard Drive Caddy: step 1, image 3 of 3
    • Flip the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
  2. PlayStation 4 Pro Power Supply Assembly Guide: step 2, image 1 of 2 PlayStation 4 Pro Power Supply Assembly Guide: step 2, image 2 of 2
    • Use a Phillips #1 Screwdriver to remove the single screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
  3. PlayStation 4 Pro Power Supply Assembly Guide, Power Supply Assembly: step 3, image 1 of 3 PlayStation 4 Pro Power Supply Assembly Guide, Power Supply Assembly: step 3, image 2 of 3 PlayStation 4 Pro Power Supply Assembly Guide, Power Supply Assembly: step 3, image 3 of 3
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
  4. PlayStation 4 Pro Power Supply Assembly Guide: step 4, image 1 of 3 PlayStation 4 Pro Power Supply Assembly Guide: step 4, image 2 of 3 PlayStation 4 Pro Power Supply Assembly Guide: step 4, image 3 of 3
    • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
    • Two 31mm screws.
    • Three 10mm screws.
    • Remove the metal plate by pulling it up.
  5. PlayStation 4 Pro Power Supply Assembly Guide: step 5, image 1 of 3 PlayStation 4 Pro Power Supply Assembly Guide: step 5, image 2 of 3 PlayStation 4 Pro Power Supply Assembly Guide: step 5, image 3 of 3
    • Flip the console over so the bottom is facing up.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel.
    • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off.
  6. PlayStation 4 Pro Power Supply Assembly Guide: step 6, image 1 of 3 PlayStation 4 Pro Power Supply Assembly Guide: step 6, image 2 of 3 PlayStation 4 Pro Power Supply Assembly Guide: step 6, image 3 of 3
    • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
    • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
    • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
  7. PlayStation 4 Pro Power Supply Assembly Guide: step 7, image 1 of 2 PlayStation 4 Pro Power Supply Assembly Guide: step 7, image 2 of 2
    • Pull the white connector straight out of the yellow mount on the motherboard.
  8. PlayStation 4 Pro Power Supply Assembly Guide: step 8, image 1 of 2 PlayStation 4 Pro Power Supply Assembly Guide: step 8, image 2 of 2
    • Pull out the five small, blue low profile cables connected to the metal plate.
    • Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull the large ribbon cable from its socket.
    • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
  9. PlayStation 4 Pro Power Supply Assembly Guide: step 9, image 1 of 1
    • Pull up and remove the metal plate.
  10. PlayStation 4 Pro Power Supply Assembly Guide: step 10, image 1 of 3 PlayStation 4 Pro Power Supply Assembly Guide: step 10, image 2 of 3 PlayStation 4 Pro Power Supply Assembly Guide: step 10, image 3 of 3
    • Flip the console over to continue working on the top side.
    • Pull up on the power supply unit and set it on the console.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
Thomas
3,877 Reputation
5 Guides authored
Cal Poly, Team S21-G5, Livingston Spring 2017 Member of Cal Poly, Team S21-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G5
4 Members
49 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 9
All Time: 443
