PlayStation 4 Optical Drive Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Video Overview
    1. PlayStation 4 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
      • Disconnect the ribbon wire from the optical drive by pressing down on the metal release tab and gently pulling the ribbon wire. This should not require force.
      Ask FixBot
    2. PlayStation 4 Optical Drive Replacement: step 2, image 1 of 1
      • Disconnect the same ribbon wire from the motherboard; making sure you're pressing down on the metal release tab and gently pulling the ribbon wire.
      Ask FixBot
    3. PlayStation 4 Optical Drive Replacement: step 3, image 1 of 1
      • Remove the wifi antenna cable attached to the motherboard.
      Ask FixBot
    4. PlayStation 4 Optical Drive Replacement: step 4, image 1 of 1
      • Remove the optical drive four wire plug from the motherboard by pulling straight out.
      Ask FixBot
    5. PlayStation 4 Optical Drive Replacement: step 5, image 1 of 1
      • Remove the four 9mm Torx T9 screw attached to the wifi antenna and optical drive.
      • Remove the 5mm Phillips head #1 screw.
      Ask FixBot
    6. PlayStation 4 Optical Drive Replacement: step 6, image 1 of 1
      • Lift up and remove the wifi antenna.
      Ask FixBot
    7. PlayStation 4 Optical Drive Replacement: step 7, image 1 of 2 PlayStation 4 Optical Drive Replacement: step 7, image 2 of 2
      • The optical drive assembly can now be lifted straight up and removed from the system. Do not discard the daughter board.
      • Be aware that the optical drive is "married" to the motherboard. If you need to replace your optical drive you must remove the daughter board on the original optical drive assembly and install it on the drive you intend to install in your PS4.
      Ask FixBot
Robert Harvey
10,799 Reputation
5 Guides authored
Cal Poly, Team 8-12, Regan Spring 2014 Member of Cal Poly, Team 8-12, Regan Spring 2014
CPSU-REGAN-S14S8G12
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 180
