PlayStation 4 Hard Drive Replacement
  1. PlayStation 4 Hard Drive Replacement, Remove the hard drive cover: step 1, image 1 of 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive cover: step 1, image 2 of 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive cover: step 1, image 3 of 3
    • Grip the PS4 with both hands along the gap in the top cover.
    • Push the glossy side of the top cover with your thumbs until it pops to the side.
    • Lift the glossy top cover up and back to remove it from the PS4.
  2. PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket screw: step 2, image 1 of 2 PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket screw: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
  3. PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket: step 3, image 1 of 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket: step 3, image 2 of 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket: step 3, image 3 of 3
    • Pull the hard drive bracket out of the enclosure.
    • Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
  4. PlayStation 4 Hard Drive Replacement, Remove the hard drive: step 4, image 1 of 2 PlayStation 4 Hard Drive Replacement, Remove the hard drive: step 4, image 2 of 2
    • Remove the two 7.2 mm screws from the right side of the hard drive tray.
  5. PlayStation 4 Hard Drive Replacement: step 5, image 1 of 2 PlayStation 4 Hard Drive Replacement: step 5, image 2 of 2
    • Remove the two 7.2 mm screws from the left side of the hard drive tray.
  6. PlayStation 4 Hard Drive Replacement: step 6, image 1 of 2 PlayStation 4 Hard Drive Replacement: step 6, image 2 of 2
    • Remove the hard drive from the hard drive tray.
Sam Omiotek
73,594 Reputation
288 Guides authored
Past 24 Hours: 36
Past 7 Days: 282
Past 30 Days: 1,364
All Time: 170,717
