PlayStation 4 Fan Replacement
  1. PlayStation 4 Fan Replacement, Remove the hard drive cover: step 1, image 1 of 3 PlayStation 4 Fan Replacement, Remove the hard drive cover: step 1, image 2 of 3 PlayStation 4 Fan Replacement, Remove the hard drive cover: step 1, image 3 of 3
    • Grip the PS4 with both hands along the gap in the top cover.
    • Push the glossy side of the top cover with your thumbs until it pops to the side.
    • Lift the glossy top cover up and back to remove it from the PS4.
  2. PlayStation 4 Fan Replacement, Remove the hard drive bracket screw: step 2, image 1 of 2 PlayStation 4 Fan Replacement, Remove the hard drive bracket screw: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
  3. PlayStation 4 Fan Replacement, Remove the hard drive bracket: step 3, image 1 of 3 PlayStation 4 Fan Replacement, Remove the hard drive bracket: step 3, image 2 of 3 PlayStation 4 Fan Replacement, Remove the hard drive bracket: step 3, image 3 of 3
    • Pull the hard drive bracket out of the enclosure.
    • Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
  4. PlayStation 4 Fan Replacement, Flip over the PS4: step 4, image 1 of 1
    • Flip the PS4 upside-down with the back side facing towards you.
  5. PlayStation 4 Fan Replacement, Remove the warranty stickers: step 5, image 1 of 3 PlayStation 4 Fan Replacement, Remove the warranty stickers: step 5, image 2 of 3 PlayStation 4 Fan Replacement, Remove the warranty stickers: step 5, image 3 of 3
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  6. PlayStation 4 Fan Replacement, Remove the plastic screw covers: step 6, image 1 of 2 PlayStation 4 Fan Replacement, Remove the plastic screw covers: step 6, image 2 of 2
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  7. PlayStation 4 Fan Replacement, Remove the rear case screws: step 7, image 1 of 2 PlayStation 4 Fan Replacement, Remove the rear case screws: step 7, image 2 of 2
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  8. PlayStation 4 Fan Replacement, Remove the lower case: step 8, image 1 of 2 PlayStation 4 Fan Replacement, Remove the lower case: step 8, image 2 of 2
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  9. PlayStation 4 Fan Replacement: step 9, image 1 of 2 PlayStation 4 Fan Replacement: step 9, image 2 of 2
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • If your connector feels stuck, use a spudger to gently pry the connector out.
  10. PlayStation 4 Fan Replacement, Remove the Wi-Fi antenna: step 10, image 1 of 2 PlayStation 4 Fan Replacement, Remove the Wi-Fi antenna: step 10, image 2 of 2
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
  11. PlayStation 4 Fan Replacement: step 11, image 1 of 3 PlayStation 4 Fan Replacement: step 11, image 2 of 3 PlayStation 4 Fan Replacement: step 11, image 3 of 3
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
  12. PlayStation 4 Fan Replacement: step 12, image 1 of 3 PlayStation 4 Fan Replacement: step 12, image 2 of 3 PlayStation 4 Fan Replacement: step 12, image 3 of 3
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
  13. PlayStation 4 Fan Replacement: step 13, image 1 of 2 PlayStation 4 Fan Replacement: step 13, image 2 of 2
    • Remove the 9.7 mm Torx security screw securing the antenna.
  14. PlayStation 4 Fan Replacement: step 14, image 1 of 2 PlayStation 4 Fan Replacement: step 14, image 2 of 2
    • Remove the Wi-Fi antenna.
  15. PlayStation 4 Fan Replacement, Disconnect the optical drive: step 15, image 1 of 3 PlayStation 4 Fan Replacement, Disconnect the optical drive: step 15, image 2 of 3 PlayStation 4 Fan Replacement, Disconnect the optical drive: step 15, image 3 of 3
    • Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
    • Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
    • You do not need to press the metal lever when inserting the ribbon cable back in. You will hear a click once it is fully inserted.
  16. PlayStation 4 Fan Replacement: step 16, image 1 of 3 PlayStation 4 Fan Replacement: step 16, image 2 of 3 PlayStation 4 Fan Replacement: step 16, image 3 of 3
    • Use your fingernail to press down the metal release lever for the ribbon cable connected to the motherboard.
    • Set the ribbon cable aside for reassembly.
  17. PlayStation 4 Fan Replacement: step 17, image 1 of 2 PlayStation 4 Fan Replacement: step 17, image 2 of 2
    • Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard.
  18. PlayStation 4 Fan Replacement: step 18, image 1 of 3 PlayStation 4 Fan Replacement: step 18, image 2 of 3 PlayStation 4 Fan Replacement: step 18, image 3 of 3
    • Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place.
  19. PlayStation 4 Fan Replacement, Remove the optical drive: step 19, image 1 of 2 PlayStation 4 Fan Replacement, Remove the optical drive: step 19, image 2 of 2
    • Remove the four screws securing the optical drive.
    • Three 9.7 mm Torx screws
    • One 6.2 mm Phillips screw
  20. PlayStation 4 Fan Replacement: step 20, image 1 of 2 PlayStation 4 Fan Replacement: step 20, image 2 of 2
    • Lift the optical drive straight up and out of the PS4.
  21. PlayStation 4 Fan Replacement, Remove the upper case: step 21, image 1 of 2 PlayStation 4 Fan Replacement, Remove the upper case: step 21, image 2 of 2
    • Remove the two 9.7 mm Torx screws securing the upper case.
  22. PlayStation 4 Fan Replacement: step 22, image 1 of 3 PlayStation 4 Fan Replacement: step 22, image 2 of 3 PlayStation 4 Fan Replacement: step 22, image 3 of 3
    • Lift the upper case up and back to remove it from the PS4.
    • The upper case in held in place by plastic tabs on the front side. It will take significant force to separate them.
  23. PlayStation 4 Fan Replacement, Remove the upper EMI shield: step 23, image 1 of 2 PlayStation 4 Fan Replacement, Remove the upper EMI shield: step 23, image 2 of 2
    • Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
  24. PlayStation 4 Fan Replacement: step 24, image 1 of 3 PlayStation 4 Fan Replacement: step 24, image 2 of 3 PlayStation 4 Fan Replacement: step 24, image 3 of 3
    • This step shows you how to properly unscrew the pressure plate.
    • Remove the two 15.6 mm Phillips screws.
    • Gradually unscrew the pressure plate by turning each screw one half turn at a time.
    • Alternate between the two screws to maintain even pressure on the pressure plate.
    • Do not unscrew one side completely before unscrewing the other side or you may damage the processor.
  25. PlayStation 4 Fan Replacement: step 25, image 1 of 1
    • Remove the pressure plate.
  26. PlayStation 4 Fan Replacement: step 26, image 1 of 2 PlayStation 4 Fan Replacement: step 26, image 2 of 2
    • Remove the upper EMI shield.
  27. PlayStation 4 Fan Replacement, Remove the motherboard: step 27, image 1 of 2 PlayStation 4 Fan Replacement, Remove the motherboard: step 27, image 2 of 2
    • Insert the flat end of a spudger in between the fan cable and the motherboard.
    • Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
  28. PlayStation 4 Fan Replacement: step 28, image 1 of 2 PlayStation 4 Fan Replacement: step 28, image 2 of 2
    • Grab the edge of the motherboard on the front of the PS4.
    • Lift the motherboard until the USB ports clear the PS4 case.
  29. PlayStation 4 Fan Replacement: step 29, image 1 of 3 PlayStation 4 Fan Replacement: step 29, image 2 of 3 PlayStation 4 Fan Replacement: step 29, image 3 of 3
    • Lift the motherboard out from the PS4.
    • Apply a new layer of thermal paste to the processor before installing a motherboard using this guide.
    • Failure to properly install new thermal paste will cause your PS4 to overheat.
    • Insert the I/O side of the Motherboard in first, then lower the other side in.
  30. PlayStation 4 Fan Replacement, Remove the lower EMI shield: step 30, image 1 of 2 PlayStation 4 Fan Replacement, Remove the lower EMI shield: step 30, image 2 of 2
    • Remove the three 6.2 mm Phillips screws from the lower EMI shield.
  31. PlayStation 4 Fan Replacement: step 31, image 1 of 2 PlayStation 4 Fan Replacement: step 31, image 2 of 2
    • Lift the lower EMI shield and heatsink straight up out of the PS4.
  32. PlayStation 4 Fan Replacement, Remove the fan: step 32, image 1 of 2 PlayStation 4 Fan Replacement, Remove the fan: step 32, image 2 of 2
    • Remove the two 6.2 mm Phillips screws from the fan.
  33. PlayStation 4 Fan Replacement: step 33, image 1 of 2 PlayStation 4 Fan Replacement: step 33, image 2 of 2
    • Lift the fan straight up out of the PS4 shell.
  34. PlayStation 4 Fan Replacement: step 34, image 1 of 3 PlayStation 4 Fan Replacement: step 34, image 2 of 3 PlayStation 4 Fan Replacement: step 34, image 3 of 3
    • Use a pair of tweezers to carefully remove the foam padding strip from the fan.
    • Install the foam padding strip to the new fan in the same location.
  35. PlayStation 4 Fan Replacement: step 35, image 1 of 3 PlayStation 4 Fan Replacement: step 35, image 2 of 3 PlayStation 4 Fan Replacement: step 35, image 3 of 3
    • Remove the foam padding pieces from the fan.
    • Use a hairdryer or heat gun to soften the adhesive if necessary.
    • Install these on the new fan in the same locations, using the adhesive left behind on the old fan as a reference.
  36. PlayStation 4 Fan Replacement: step 36, image 1 of 3 PlayStation 4 Fan Replacement: step 36, image 2 of 3 PlayStation 4 Fan Replacement: step 36, image 3 of 3
    • Remove the adhesive strip securing the fan cable.
    • Place the adhesive strip on the new fan, securing the cable in the same location.
Sam Omiotek
73,052 Reputation
288 Guides authored
Past 24 Hours: 107
Past 7 Days: 660
Past 30 Days: 3,105
All Time: 499,581
