Samsung HMX-F90 Strap Replacement
    1. Samsung HMX-F90 Strap Replacement, Battery: step 1, image 1 of 3 Samsung HMX-F90 Strap Replacement, Battery: step 1, image 2 of 3 Samsung HMX-F90 Strap Replacement, Battery: step 1, image 3 of 3
      • Pull the release tab away from the battery.
      • Slide the battery towards the release tab and then pull the battery away from the camcorder.
      Ask FixBot
    1. Samsung HMX-F90 Strap Replacement, Strap Side Outer Casing: step 2, image 1 of 2 Samsung HMX-F90 Strap Replacement, Strap Side Outer Casing: step 2, image 2 of 2
      • Rotate the camcorder so that the strap side is facing you.
      • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
      Ask FixBot
    2. Samsung HMX-F90 Strap Replacement: step 3, image 1 of 2 Samsung HMX-F90 Strap Replacement: step 3, image 2 of 2
      • Rotate the camcorder so that the battery slot is facing you.
      • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
      Ask FixBot
    3. Samsung HMX-F90 Strap Replacement: step 4, image 1 of 2 Samsung HMX-F90 Strap Replacement: step 4, image 2 of 2
      • Rotate the camcorder so you are looking at the bottom of the camcorder.
      • Locate and remove the last three 4.5mm Phillips #00 screws.
      Ask FixBot
    4. Samsung HMX-F90 Strap Replacement: step 5, image 1 of 3 Samsung HMX-F90 Strap Replacement: step 5, image 2 of 3 Samsung HMX-F90 Strap Replacement: step 5, image 3 of 3
      • With both hands, pull the side strap apart from the rest of the camcorder.
      Ask FixBot
    1. Samsung HMX-F90 Strap Replacement, Hand Strap: step 6, image 1 of 3 Samsung HMX-F90 Strap Replacement, Hand Strap: step 6, image 2 of 3 Samsung HMX-F90 Strap Replacement, Hand Strap: step 6, image 3 of 3
      • Unfasten the strap from the outside.
      • Pull apart the velcro on the faux leather strap sheath to reveal the separate end of the strap.
      • The loose end can be pulled off the velcro and fed through the loop on the casing to free one end of the strap.
      Ask FixBot
    2. Samsung HMX-F90 Strap Replacement: step 7, image 1 of 3 Samsung HMX-F90 Strap Replacement: step 7, image 2 of 3 Samsung HMX-F90 Strap Replacement: step 7, image 3 of 3
      • On the inside of the opened case, locate the silver metal plate and remove the 3mm Phillips screw.
      • Feed the strap through the hole to remove completely so that it can be replaced or cleaned.
      Ask FixBot
Amir Harb
705 Reputation
6 Guides authored
USF Tampa, Team S13-G1, Boczar Fall 2017 Member of USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 42
All Time: 854
