PlayStation 3 Top Cover Replacement
  1. PlayStation 3 Top Cover Replacement, Smart Plate: step 1, image 1 of 2 PlayStation 3 Top Cover Replacement, Smart Plate: step 1, image 2 of 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Top Cover Replacement: step 2, image 1 of 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Top Cover Replacement: step 3, image 1 of 3 PlayStation 3 Top Cover Replacement: step 3, image 2 of 3 PlayStation 3 Top Cover Replacement: step 3, image 3 of 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Top Cover Replacement: step 4, image 1 of 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Top Cover Replacement, Top Cover: step 5, image 1 of 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Top Cover Replacement: step 6, image 1 of 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
Past 24 Hours: 19
Past 7 Days: 81
Past 30 Days: 397
All Time: 50,342
