PlayStation 3 Slim Top Shield Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. PlayStation 3 Slim Top Shield Assembly Replacement, Top Shield Assembly: step 1, image 1 of 1
    • Disconnect the DC-In and Blu-ray power cables from the motherboard.
    • Pull the cables straight upward to lift the connectors up and out of their sockets on the motherboard.
  2. PlayStation 3 Slim Top Shield Assembly Replacement: step 2, image 1 of 1
    • Pull the fan cables straight up to lift the fan connector up and out of its socket on the motherboard.
  3. PlayStation 3 Slim Top Shield Assembly Replacement: step 3, image 1 of 1
    • Remove the following nine screws holding the motherboard assembly together:
    • Four 14.8 mm shouldered Phillips
    • Five 9.5 mm Phillips
  4. PlayStation 3 Slim Top Shield Assembly Replacement: step 4, image 1 of 1
    • Remove the two heat sink clamps from the bottom of the motherboard assembly.
  5. PlayStation 3 Slim Top Shield Assembly Replacement: step 5, image 1 of 1
    • If necessary, gently pry the motherboard off the top shield near the heat sink and its shroud.
  6. PlayStation 3 Slim Top Shield Assembly Replacement: step 6, image 1 of 2 PlayStation 3 Slim Top Shield Assembly Replacement: step 6, image 2 of 2
    • Gently press the board away from the top shield assembly near the fan connector and the corner of the board near the wireless sockets.
  7. PlayStation 3 Slim Top Shield Assembly Replacement: step 7, image 1 of 1
    • Lift the top shield assembly off the motherboard from its front edge.
    • Be careful not to damage the sockets as you rotate the top shield assembly away from the motherboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 6
All Time: 1,754
