PlayStation 3 Slim Hard Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. PlayStation 3 Slim Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 PlayStation 3 Slim Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Turn the PS3 over and lay it on its backside.
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  2. PlayStation 3 Slim Hard Drive Replacement: step 2, image 1 of 1
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  3. PlayStation 3 Slim Hard Drive Replacement: step 3, image 1 of 2 PlayStation 3 Slim Hard Drive Replacement: step 3, image 2 of 2
    • Using its attached metal handle, pull the hard drive out of its bay.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,156
