PlayStation 3 Slim Blu-ray Disc Drive Replacement
  1. PlayStation 3 Slim Blu-ray Disc Drive Replacement, Top Cover: step 1, image 1 of 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 2, image 1 of 2 PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 2, image 2 of 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 3, image 1 of 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 4, image 1 of 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 5, image 1 of 2 PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 5, image 2 of 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim Blu-ray Disc Drive Replacement, Power Supply: step 6, image 1 of 2 PlayStation 3 Slim Blu-ray Disc Drive Replacement, Power Supply: step 6, image 2 of 2
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 7, image 1 of 1
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  8. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 8, image 1 of 1
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  9. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 9, image 1 of 1
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  10. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 10, image 1 of 2 PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 10, image 2 of 2
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  11. PlayStation 3 Slim Blu-ray Disc Drive Replacement, Blu-ray Disc Drive: step 11, image 1 of 2 PlayStation 3 Slim Blu-ray Disc Drive Replacement, Blu-ray Disc Drive: step 11, image 2 of 2
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  12. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 12, image 1 of 1
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  13. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 13, image 1 of 1
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  14. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 14, image 1 of 1
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  15. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 15, image 1 of 1
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  16. PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 16, image 1 of 2 PlayStation 3 Slim Blu-ray Disc Drive Replacement: step 16, image 2 of 2
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
Past 24 Hours: 38
Past 7 Days: 275
Past 30 Days: 1,300
All Time: 294,372
