PlayStation 3 Slim AC Inlet Replacement
  1. PlayStation 3 Slim AC Inlet Replacement, Top Cover: step 1, image 1 of 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim AC Inlet Replacement: step 2, image 1 of 2 PlayStation 3 Slim AC Inlet Replacement: step 2, image 2 of 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim AC Inlet Replacement: step 3, image 1 of 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim AC Inlet Replacement: step 4, image 1 of 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim AC Inlet Replacement: step 5, image 1 of 2 PlayStation 3 Slim AC Inlet Replacement: step 5, image 2 of 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim AC Inlet Replacement, Power Supply: step 6, image 1 of 2 PlayStation 3 Slim AC Inlet Replacement, Power Supply: step 6, image 2 of 2
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. PlayStation 3 Slim AC Inlet Replacement: step 7, image 1 of 1
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  8. PlayStation 3 Slim AC Inlet Replacement: step 8, image 1 of 1
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  9. PlayStation 3 Slim AC Inlet Replacement: step 9, image 1 of 1
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  10. PlayStation 3 Slim AC Inlet Replacement: step 10, image 1 of 2 PlayStation 3 Slim AC Inlet Replacement: step 10, image 2 of 2
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  11. PlayStation 3 Slim AC Inlet Replacement, AC Inlet: step 11, image 1 of 2 PlayStation 3 Slim AC Inlet Replacement, AC Inlet: step 11, image 2 of 2
    • Lift the AC inlet cables straight upward to remove the AC inlet from the lower case.
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 132
All Time: 25,211
