PlayStation 3 Heat Sink Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. PlayStation 3 Heat Sink Replacement, Heat Sink: step 1, image 1 of 2 PlayStation 3 Heat Sink Replacement, Heat Sink: step 1, image 2 of 2
    • De-route the fan cables from the plastic finger molded into the heat sink.
    • Disconnect the fan from the motherboard.
    • Pull the connector straight up and out of its socket.
  2. PlayStation 3 Heat Sink Replacement: step 2, image 1 of 1
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  3. PlayStation 3 Heat Sink Replacement: step 3, image 1 of 2 PlayStation 3 Heat Sink Replacement: step 3, image 2 of 2
    • Lift the memory card reader out of the PS3 enough to access its ribbon cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket and remove the memory card reader.
  4. PlayStation 3 Heat Sink Replacement: step 4, image 1 of 1
    • Disconnect the DC-In cables from the front of the heat sink.
    • Pull the connector toward the front of the PS3.
  5. PlayStation 3 Heat Sink Replacement: step 5, image 1 of 1
    • Remove the five 9 mm Phillips screws securing the power supply to the chassis.
  6. PlayStation 3 Heat Sink Replacement: step 6, image 1 of 1
    • Lift the power supply by its front edge to clear the two posts attached to the motherboard.
    • Remove the power supply.
  7. PlayStation 3 Heat Sink Replacement: step 7, image 1 of 1
    • Remove the four 16.5 mm shouldered Phillips screws securing the heat sink to the motherboard.
    • Remove the two brackets held under the screws you just removed.
  8. PlayStation 3 Heat Sink Replacement: step 8, image 1 of 1
    • Lift the motherboard assembly off the heat sink.
    • The heat sink may still be held in place by the thermal paste. If this is the case, gently pry the heat sink away from the motherboard housing. Make sure to not bend the copper piping on the heat sink.
    • Be sure to apply a new layer of thermal paste when reattaching the heat sink.
    • Never applied thermal paste before? Our thermal paste guide makes it easy.
    • If you're following the YLOD repair guide, stay tuned for where to apply the replacement thermal paste.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 2,835
