PlayStation 2 Slimline PVR-802W Laser Replacement
  1. PlayStation 2 Slimline PVR-802W Laser Replacement, Outer Shell: step 1, image 1 of 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline PVR-802W Laser Replacement: step 2, image 1 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement: step 2, image 2 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement: step 2, image 3 of 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline PVR-802W Laser Replacement: step 3, image 1 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement: step 3, image 2 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement: step 3, image 3 of 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline PVR-802W Laser Replacement: step 4, image 1 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement: step 4, image 2 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement: step 4, image 3 of 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline PVR-802W Laser Replacement, Remove screws and brackets: step 5, image 1 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove screws and brackets: step 5, image 2 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove screws and brackets: step 5, image 3 of 3
    • Remove the 2 philips screws
    • Remove the brackets on both sides with your tweezers.
  6. PlayStation 2 Slimline PVR-802W Laser Replacement, Remove silver rail: step 6, image 1 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove silver rail: step 6, image 2 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove silver rail: step 6, image 3 of 3
    • If you got the same results as in the 1st photo, then proceed.
    • Take the silver rail and push it out *carefully* from the track.
    • Take the silver rail with your tweezers and pull it towards yourself to take it out. Be carefull, as it still attached to the laser, just guide it slowly towards yourself.
  7. PlayStation 2 Slimline PVR-802W Laser Replacement, Remove laser: step 7, image 1 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove laser: step 7, image 2 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Remove laser: step 7, image 3 of 3
    • Take the laser with your hand, and till it like in the photo (to the back).
    • Open the ZIF connector. Be carefull not to break it, it can break easily. If you replace the laser, it won't matter, you can even practice how to open it and close it.
    • Take out the ribbon cable and remove the laser.
  8. PlayStation 2 Slimline PVR-802W Laser Replacement, Desoldering the anti-static security: step 8, image 1 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Desoldering the anti-static security: step 8, image 2 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Desoldering the anti-static security: step 8, image 3 of 3
    • It's important to remove the anti-static security, otherwise it won't work! Some lasers come without the anti-static security.
    • Remove the anti-static security. Use some copper wick to remove the solder.
    • When it looks like in the 3rd photo, you are good to.
  9. PlayStation 2 Slimline PVR-802W Laser Replacement, Transfer holder: step 9, image 1 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Transfer holder: step 9, image 2 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Transfer holder: step 9, image 3 of 3
    • Remove the single philips screw.
    • Transfer the holder to the new laser and fasten it again with the philips screw.
  10. PlayStation 2 Slimline PVR-802W Laser Replacement, Place the new laser in: step 10, image 1 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Place the new laser in: step 10, image 2 of 3 PlayStation 2 Slimline PVR-802W Laser Replacement, Place the new laser in: step 10, image 3 of 3
    • Take the new laser and open up the ZIF connector.
    • Place it back as shown in the 2nd photo.
    • Put everything back together. The 3rd picture show how it needs to be done!
koppie007
11,926 Reputation
9 Guides authored
Protectors Of The Game Systems Member of Protectors Of The Game Systems
Community
4 Members
24 Guides authored
Past 24 Hours: 15
Past 7 Days: 176
Past 30 Days: 879
All Time: 25,020
