PlayStation 2 Optical Disc Drive Laser Assembly Replacement
  1. PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: step 1, image 1 of 3 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: step 1, image 2 of 3 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: step 1, image 3 of 3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: step 2, image 1 of 1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: step 3, image 1 of 1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: step 4, image 1 of 2 PlayStation 2 Optical Disc Drive Laser Assembly Replacement: step 4, image 2 of 2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
  5. PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Optical Disc Drive Laser Assembly: step 5, image 1 of 2 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Optical Disc Drive Laser Assembly: step 5, image 2 of 2
    • Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
    • Lift and remove the lid from the optical disc drive.
  6. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: step 6, image 1 of 1
    • Remove the two 7.2 mm Phillips black screws securing the metal silver rails that hold the laser in place.
  7. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: step 7, image 1 of 1
    • Use your fingernail to flip up the retaining flap on the optical disc drive laser ribbon cable.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
    • Pull the optical disc drive laser ribbon cable straight away and out of its socket.
    • If you maneuver the unscrewed ends of the metal rails upwards, the laser will slide out.
jwyoung
2,818 Reputation
5 Guides authored
Cal Poly, Team 19-1, Maness Fall 2009 Member of Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Members
34 Guides authored
Past 24 Hours: 21
Past 7 Days: 124
Past 30 Days: 498
All Time: 79,357
