Introduction
Replace the laser assembly in your optical disc drive. Replacing the laser requires you to have or purchase a new laser.
Use the flat edge of a metal spudger to pry the eight flat screw covers out.
Remove the following eight screws securing the top cover to the bottom case:
Four 55.4 mm Philips screws
Four 18.0 mm Phillips screws
Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
Peel the warranty sticker (located next to the main power switch) straight away from the case.
Lift the top cover off the bottom case.
Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
Lift and remove the lid from the optical disc drive.
Remove the two 7.2 mm Phillips black screws securing the metal silver rails that hold the laser in place.
Use your fingernail to flip up the retaining flap on the optical disc drive laser ribbon cable.
Pull the optical disc drive laser ribbon cable straight away and out of its socket.
