Disassembling PlayStation 2 Fan
  1. Disassembling PlayStation 2 Fan, Top Cover: step 1, image 1 of 3 Disassembling PlayStation 2 Fan, Top Cover: step 1, image 2 of 3 Disassembling PlayStation 2 Fan, Top Cover: step 1, image 3 of 3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. Disassembling PlayStation 2 Fan: step 2, image 1 of 1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. Disassembling PlayStation 2 Fan: step 3, image 1 of 1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. Disassembling PlayStation 2 Fan: step 4, image 1 of 2 Disassembling PlayStation 2 Fan: step 4, image 2 of 2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
  5. Disassembling PlayStation 2 Fan, Power Board: step 5, image 1 of 2 Disassembling PlayStation 2 Fan, Power Board: step 5, image 2 of 2
    • Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
    • Lift and remove the optical disc drive straight up out of the bottom case.
  6. Disassembling PlayStation 2 Fan: step 6, image 1 of 2 Disassembling PlayStation 2 Fan: step 6, image 2 of 2
    • Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
  7. Disassembling PlayStation 2 Fan: step 7, image 1 of 2 Disassembling PlayStation 2 Fan: step 7, image 2 of 2
    • Gently lift the controller port board out of its recess within the bottom case.
    • Do not completely remove the controller port board. It is still attached via a ribbon cable.
    • Pull the controller port ribbon cable straight away from its socket on the controller port board.
    • Remove the controller port board out of the bottom case.
  8. Disassembling PlayStation 2 Fan: step 8, image 1 of 1
    • Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
  9. Disassembling PlayStation 2 Fan: step 9, image 1 of 1
    • If there is a device occupying the expansion bay, make sure to remove the device. The expansion base should be empty.
    • Pry and remove the expansion bay cover away from its posts on the bottom case.
  10. Disassembling PlayStation 2 Fan: step 10, image 1 of 1
    • Lift the motherboard assembly from its front edge and remove it from the lower case.
  11. Disassembling PlayStation 2 Fan: step 11, image 1 of 1
    • Now that all of that bulky plastic is out of the way, we can get to the fun stuff - electronics!
    • Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
  12. Disassembling PlayStation 2 Fan: step 12, image 1 of 1
    • Lift the expansion bay cage up off the motherboard assembly.
  13. Disassembling PlayStation 2 Fan: step 13, image 1 of 2 Disassembling PlayStation 2 Fan: step 13, image 2 of 2
    • Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch.
    • Carefully lift the power board. You should now see the power board connector attached to the power board.
    • Pull the power board connector straight to lift it out of its socket on the power board.
  14. Disassembling PlayStation 2 Fan, Fan: step 14, image 1 of 1
    • The transparent piece of plastic located underneath the power supply recess in the motherboard assembly is the heat shield.
    • Remove the heat shield from the motherboard assembly.
    • Dislodging the heat shield can be a bit stubborn, so it may take a little finessing to get it free.
  15. Disassembling PlayStation 2 Fan: step 15, image 1 of 3 Disassembling PlayStation 2 Fan: step 15, image 2 of 3 Disassembling PlayStation 2 Fan: step 15, image 3 of 3
    • We can now remove the fan and main power switch assembly.
    • Remove the small white piece of tape (highlighted in red) that holds the fan cable connected to the fan.
    • Pull the fan cable straight up from its socket on the motherboard.
    • The fan and power switch are now free from the rest of the PlayStation 2.
    • Remove the fan and power switch assembly by pulling it out the bottom case.
  16. Disassembling PlayStation 2 Fan: step 16, image 1 of 1
    • Remove the fan from the power switch assembly.
    • The fan simply slides out of the top along its track.
  17. Disassembling PlayStation 2 Fan: step 17, image 1 of 1
    • Remove the power switch from its recess within the fan/power switch holder.
    • The power switch simply slides out just like the fan.
jwyoung
2,809 Reputation
5 Guides authored
Cal Poly, Team 19-1, Maness Fall 2009 Member of Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Members
34 Guides authored
Past 24 Hours: 13
Past 7 Days: 125
Past 30 Days: 568
All Time: 101,552
