Plastic Tooth Zipper Diagnosis
  1. Plastic Tooth Zipper Diagnosis, Plastic Tooth Zipper Diagnosis: step 1, image 1 of 2 Plastic Tooth Zipper Diagnosis, Plastic Tooth Zipper Diagnosis: step 1, image 2 of 2
    • Before we get started, let's identify the basic parts of a plastic tooth zipper:
    • Slider
    • Pull
    • Stop
    • Box
    • Teeth
    • Zipper Tape
  2. Plastic Tooth Zipper Diagnosis: step 2, image 1 of 1
    • The teeth on this zipper are melted.
    • This zipper cannot be repaired and needs to be replaced.
  3. Plastic Tooth Zipper Diagnosis: step 3, image 1 of 1
    • The teeth are missing from the zipper.
    • This zipper cannot be repaired, so the zipper will need to be replaced.
  4. Plastic Tooth Zipper Diagnosis: step 4, image 1 of 2 Plastic Tooth Zipper Diagnosis: step 4, image 2 of 2
    • This zipper is missing the zipper box at the bottom of the zipper.
  5. Plastic Tooth Zipper Diagnosis: step 5, image 1 of 2 Plastic Tooth Zipper Diagnosis: step 5, image 2 of 2
    • This zipper is missing the zipper stop at the top of the zipper.
    • Provided there is enough of the fabric around the zipper, which has been clipped in this image for visibility, you can simply replace the stop as shown in our slider replacement guide.
Finish Line
7 other people completed this guide.
Brittany McCrigler
89,014 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
5 Comments
The link in Step 5 for the slider replacement guide is incorrect. It points to a Powerbook HD replacement guide. TG.
tgarrity - Reply
What if there's no reason other than one side of the slider came off?
Donna Brock - Reply
What about if the zipper zips up but the teeth do not keep closed. I.e. zip up the jacket, part of the teeth stay interlocked but from one point on the teeth become undone and do not lock.
Juan Umana - Reply
That's an issue with the zipper slider itself and I have experience fixing it. It's difficult to maneuver the tool because of fabric in the way and it's in a generally awkward spot but possible. Take needle pliers and squeeze down *a little bit* on the back of the zipper slider itself. Doesn't need too much of an adjustment, so squeeze a little and check, and squeeze a little and check. It's the small end of the zipper slider.
Malm -
I have the same problem as Juan Umana: one tooth at the bottom (beginning) of the zipper is broken off, so the teeth won’t mesh properly and the zipper teeth stay apart. Ideas welcome.
Robin Cunningham
Robin Cunningham - Reply
Past 24 Hours: 4
Past 7 Days: 67
Past 30 Days: 256
All Time: 40,488
