Shop the Holiday Gift Guide
Planet Eclipse Etha Trigger Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
91
All Time:
1,488
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The trigger on the Etha doesn't break often, but you may choose to replace it for a trigger you prefer or it may simply need cleaning.
Tools
    1. Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: step 1, image 1 of 2 Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: step 1, image 2 of 2
      • Use the 5/64" hex key to remove the screw shown.
      • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
      • If you are only replacing the battery, skip the next step.
      • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
      Ask FixBot
    2. Planet Eclipse Etha Trigger Replacement: step 2, image 1 of 1
      • Flip the marker over and use the 5/64" hex key to remove the screw shown.
      Ask FixBot
    3. Planet Eclipse Etha Trigger Replacement: step 3, image 1 of 2 Planet Eclipse Etha Trigger Replacement: step 3, image 2 of 2
      • Carefully remove the 9V battery and connector.
      • Remove the 9V battery from the connector.
      Ask FixBot
    1. Planet Eclipse Etha Trigger Replacement, Trigger: step 4, image 1 of 1
      • Use a hex key to unscrew the middle screw on the top of the trigger.
      Ask FixBot
    2. Planet Eclipse Etha Trigger Replacement: step 5, image 1 of 1
      • Use same hex key to push through trigger retention pin on the side of the gun.
      Ask FixBot
    3. Planet Eclipse Etha Trigger Replacement: step 6, image 1 of 2 Planet Eclipse Etha Trigger Replacement: step 6, image 2 of 2
      • Pull out the trigger by grabbing the bottom and slowly rotating outwards.
      Ask FixBot
Author
with
Evan Hench
223 Reputation
1 Guide authored
Cal Poly, Team 10-42, Amido Fall 2014 Member of Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 91
All Time: 1,488
