Use your finger to press down and connect the three rear camera press connectors.
Slide the top corners of the front camera bracket under the lip in the frame and press the clip in to secure it.
Check the condition of the motherboard thermal pad—it'll either be on the bottom edge of the board or on the underside of the cover.
Use the flat end of a spudger to gently scrape up and remove all the old thermal pad from the board and cover.
Use high‑concentration (>90%) isopropyl alcohol and a coffee filter (or lint‑free cloth) to clean up any thermal pad residue from the board and cover.
Allow the alcohol to dry completely before continuing.
Remove the larger liner (without cutouts) from the thermal pad.
Lay the thermal pad in its square cutout on the underside of the motherboard cover.
Press down firmly on the entire surface of the pad with your finger or the flat end of a spudger.
Slowly peel up the remaining liner.
Use your finger to press down and connect the battery press connector.
